2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 1 | -1/+1 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 1 | -1/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 1 | -3/+2 | |
2017-11-13 | Clean up sphinx warnings. | Chris Johns | 1 | -15/+26 | |
- Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | |||||
2017-11-12 | c-user: Fix index locations. | Chris Johns | 1 | -34/+38 | |
2017-04-25 | c-user/rate_monotonic_manager.rst: Use Latex math for utilization formulas | Joel Sherrill | 1 | -9/+8 | |
2017-01-31 | Fix refs.bib entry | Sebastian Huber | 1 | -1/+1 | |
2017-01-30 | c-user: Update overrun handling related functions and structure | Kuan-Hsun Chen | 1 | -34/+23 | |
State the limited count of postponed_jobs. Update _rtems_rate_monotonic_get_status() and related structure. Move "Further Reading" in c-user to references. Add mentioned papers in ticket #2795 to references. Update #2795. | |||||
2017-01-13 | Update documentation to reflect EDF scheduler overrun handling | Kuan-Hsun Chen | 1 | -12/+16 | |
2016-11-09 | c-user: Fix header levels. Minor fixes. | Chris Johns | 1 | -8/+8 | |
2016-11-08 | c-user: Format the directives as descriptions. | Chris Johns | 1 | -292/+286 | |
This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | |||||
2016-11-03 | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 1 | -0/+0 | |
2016-10-28 | object_services.rst: Add _rtems_object_id_api_minimum_class and ↵ | Joel Sherrill | 1 | -1/+1 | |
_rtems_object_id_api_maximum_class | |||||
2016-09-14 | c_user: Fix minor error. | Chris Johns | 1 | -1/+1 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 1 | -0/+2 | |
2016-05-02 | Fix formatting. | Chris Johns | 1 | -1/+1 | |
2016-05-02 | Change code to code-block. | Chris Johns | 1 | -15/+15 | |
2016-05-02 | Add an rtems-table class to wrap and align HTML tables. | Chris Johns | 1 | -0/+9 | |
2016-05-02 | Cleanups. | Chris Johns | 1 | -61/+61 | |
2016-05-02 | C user guide clean up. Up to timer manager. | Chris Johns | 1 | -568/+576 | |
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 1 | -14/+14 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -105/+153 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -0/+1021 | |
