2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 1 | -1/+1 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 1 | -1/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 1 | -2/+1 | |
2017-11-13 | Clean up sphinx warnings. | Chris Johns | 1 | -21/+42 | |
- Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | |||||
2017-11-12 | c-user: Fix index locations. | Chris Johns | 1 | -22/+21 | |
2017-02-15 | c-user: Fix linker set code blocks | Sebastian Huber | 1 | -12/+13 | |
2017-02-15 | c-user: Document linker set content | Sebastian Huber | 1 | -0/+48 | |
Close #2770. | |||||
2016-12-12 | Update Initialization Manager chapter | Sebastian Huber | 1 | -1/+1 | |
Update #2408. | |||||
2016-12-06 | Update linker set documentation | Sebastian Huber | 1 | -2/+93 | |
Update #2408. Update #2790. | |||||
2016-11-09 | c-user: Fix header levels. Minor fixes. | Chris Johns | 1 | -1/+1 | |
2016-11-08 | c-user: Format the directives as descriptions. | Chris Johns | 1 | -250/+267 | |
This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | |||||
2016-11-03 | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 1 | -0/+0 | |
2016-10-28 | c_user: Remove errors and warnings. | Chris Johns | 1 | -0/+2 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 1 | -0/+2 | |
2016-05-02 | Minor fixes. | Chris Johns | 1 | -3/+3 | |
2016-05-02 | Clean up. | Chris Johns | 1 | -147/+216 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -0/+0 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -0/+447 | |
