* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 1 | -1/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 1 | -2/+1 |
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 1 | -21/+42 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | c-user: Fix index locations. | Chris Johns | 2017-11-12 | 1 | -22/+21 |
* | c-user: Fix linker set code blocks | Sebastian Huber | 2017-02-15 | 1 | -12/+13 |
* | c-user: Document linker set content | Sebastian Huber | 2017-02-15 | 1 | -0/+48 |
| | | | | Close #2770. | ||||
* | Update Initialization Manager chapter | Sebastian Huber | 2016-12-12 | 1 | -1/+1 |
| | | | | Update #2408. | ||||
* | Update linker set documentation | Sebastian Huber | 2016-12-06 | 1 | -2/+93 |
| | | | | | Update #2408. Update #2790. | ||||
* | c-user: Fix header levels. Minor fixes. | Chris Johns | 2016-11-09 | 1 | -1/+1 |
* | c-user: Format the directives as descriptions. | Chris Johns | 2016-11-08 | 1 | -250/+267 |
| | | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | ||||
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 1 | -0/+520 |
