* | c-user: Add Local vs Global to Key Concepts Chapter | Joel Sherrill | 2022-12-07 | 1 | -8/+68 |
| | | | | | | | Add multiple new index entries and cite them where RTEMS_LOCAL and RTEMS_GLOBAL are cited. Closes #4453. | ||||
* | c-user/*: Add trailing parentheses on methods in index which were missing it | Joel Sherrill | 2022-11-30 | 1 | -6/+6 |
| | | | | Closes #4766. | ||||
* | c-user: Do not mention pseudo-interrupt priority | Sebastian Huber | 2022-07-26 | 1 | -1/+1 |
| | | | | Update #2365. | ||||
* | Address several issues from compiling examples | Martin Erik Werner | 2019-09-03 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Compiling the code from examples "code-block:: c" along with public includes and a bsp exposed a few issues amongst a lot of false positives. Address some of these: * Terminate struct declarations with ';'. Mainly for pedantic correctness. * Show ptrdiff_t instead of size_t for the sbrk() prototype, matching the current argument type in rtems. * Replace some occurrences of unsigned16 with uint16_t. * Fix odd type declaration, "uint8_t char*" -> "char*". * Use appropriate helper to get chain head instead of invalid access to nonexistent struct member. * Remove several excess '\' escapes. * Use RTEMS_SELF instead of undefined SELF. * Use rtems_task instead of void for task functions. * Add missing stack size parameter in task creation. * Use rtems_interrupt_level instead of undefined rtems_interrupt. * Correct return value format for rtems_object_id_get_api() rtems_object_id_get_index() (enum and uint16_t) and also fix corresponding print formatting. * Correct return value documentation for rtems_object_id_get_class(), rtems_object_id_get_node() and rtems_object_id_get_index() int -> uint32_t. * Use RTEMS_SUCCESSFUL instead of undefined RTEMS_STATUS_SUCCESSFUL and fix return value variable name in rate monotonic examples. * Use RTEMS_TIMEOUT instead of undefined TIMEOUT and RTEMS_PERIOD_STATUS instead of undefined STATUS. * Add missing fields to ftpd configuration. * Correct parameter types in ftpd hook prototype, unsigned char * -> void *. * Fix various code-block:: attributes, c -> makefile and c -> shell. * Add missing parenthesis in socket buffer memory calculation example. * Remove typedef in declaration of mq_attr since it is defiend without typedef in reality. * Update siginfo_t declaration to match current reality. * Update shell user command definition example to include mode, uid and gid. | ||||
* | c-user: Mention transitive priority inheritance | Sebastian Huber | 2019-04-10 | 1 | -1/+4 |
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 1 | -1/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 1 | -2/+1 |
* | c-user: Remove 16-bit object identifiers | Sebastian Huber | 2018-11-21 | 1 | -36/+8 |
| | | | | Close #3603. | ||||
* | c-user: Use uniprocessor throughout | Sebastian Huber | 2018-03-07 | 1 | -2/+2 |
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 1 | -5/+10 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | c-user: Fix index locations. | Chris Johns | 2017-11-12 | 1 | -18/+27 |
* | Change RTEMS version to 5 | Sebastian Huber | 2017-11-09 | 1 | -7/+7 |
| | | | | Update #3220. | ||||
* | c-user: Replace pre-emption with preemption | Sebastian Huber | 2017-05-11 | 1 | -2/+2 |
* | c-user: Use sphinx glossary support | Sebastian Huber | 2017-02-02 | 1 | -6/+6 |
| | | | | Terms can be referenced via :term:`XYZ`. | ||||
* | c-user: Add Key concept locking protocols | Sebastian Huber | 2017-02-01 | 1 | -0/+116 |
| | | | | | Update #2412. Update #2556. | ||||
* | c-user: Add key concept thread queues | Sebastian Huber | 2017-02-01 | 1 | -0/+60 |
* | c-user: Add timer and timeouts key concept | Sebastian Huber | 2017-01-30 | 1 | -0/+40 |
| | | | | Update #2554. | ||||
* | c-user: Update key concepts time | Sebastian Huber | 2017-01-30 | 1 | -10/+13 |
* | c-user: Fix header levels. Minor fixes. | Chris Johns | 2016-11-09 | 1 | -1/+1 |
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 1 | -0/+314 |
