* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 1 | -1/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 1 | -2/+1 |
* | c-user: Use uniprocessor throughout | Sebastian Huber | 2018-03-07 | 1 | -3/+3 |
* | c-user: Clarify local interrupt disable | Sebastian Huber | 2017-12-01 | 1 | -3/+6 |
* | c-user: Clarify interrupt manager directives | Sebastian Huber | 2017-11-30 | 1 | -58/+137 |
| | | | | Use RTEMS coding style in all code blocks. | ||||
* | c-user: Clarify rtems_interrupt_flash() | Sebastian Huber | 2017-11-20 | 1 | -7/+11 |
* | c-user: Remove clock driver specific functions | Sebastian Huber | 2017-11-17 | 1 | -3/+0 |
| | | | | | | Do not mention functions which belong to a specific clock driver implementation. These functions should not be called by applications directly. | ||||
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 1 | -12/+24 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | c-user: Fix index locations. | Chris Johns | 2017-11-12 | 1 | -23/+28 |
* | c-user: Update to reflect rtems_clock_get() being obsoleted. | Joel Sherrill | 2017-10-11 | 1 | -1/+0 |
| | | | | Closes #2693. | ||||
* | c-user: Fix interrupt lock documentation | Sebastian Huber | 2017-07-14 | 1 | -17/+35 |
| | | | | Update #3075. | ||||
* | Use "in X config..." instead of "on X config..." | Sebastian Huber | 2017-02-01 | 1 | -9/+9 |
* | c-user: Fix header levels. Minor fixes. | Chris Johns | 2016-11-09 | 1 | -11/+11 |
* | c-user: Format the directives as descriptions. | Chris Johns | 2016-11-08 | 1 | -226/+217 |
| | | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | ||||
* | Update due to clock manager and driver changes | Sebastian Huber | 2016-11-03 | 1 | -2/+3 |
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 1 | -0/+664 |
