Introduce a background section.
This makes it easier to automatically generate parts of the scheduling
concepts documentation in the future.
Update #3993.
This makes it easier to automatically generate parts of the manager
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Introduce an index file for this chapter. This helps to generate some
sections from the specification in the future. Start with moving
"Introduction" up to "Unlimited Objects" to a new file.
Update #3836.
Adjust copyright. Linker sets were introduced in 2015.
Update #2408.
Close #3865.
- This change makes the copyright character easier to see on editors
lacking good unicode rendering support, ie terminals.
For everything before 2015 an OAR copyright is assumed. Later copyright
notices are based on Git commits on a best effort basis.
The copyright notices of the "RTEMS Software Engineering Handbook" and
the "RTEMS CPU Architecture Supplement" are incomplete.
- Remove all genindex.rst files, these are generated and should not
exist in our source.
- Fix the HTML templates so the local specialisation works.
- Add a index link to the sidebar for HTML.
Note, there is no TOC entry for the index in the PDF output and I
cannot figure out how to add one.
Closes #3503
Update #2843.
Update #3229.
https://sphinxcontrib-bibtex.readthedocs.io/en/latest/index.html
Update #2871.
closes #2589.
This change combined with the element list change in latex generates
a much better looking PDF.
Add a page break before each directive to like th previous versions of the
manuals.
