* | Reformat and update copyright and license notices | Sebastian Huber | 2019-01-14 | 1 | -7/+8 |
| | | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 1 | -23/+1 |
* | Update the copyright year. | Chris Johns | 2018-10-19 | 1 | -1/+1 |
* | c-user/index.rst: Reorder linker sets and directive status codes | Joel Sherrill | 2018-10-11 | 1 | -1/+1 |
* | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2018-08-21 | 1 | -1/+1 |
| | | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | ||||
* | c-user: Add self-contained objects chapter | Sebastian Huber | 2018-02-05 | 1 | -0/+1 |
| | | | | Update #2843. | ||||
* | Add indexes to all documents. | Chris Johns | 2017-11-12 | 1 | -2/+1 |
| | | | | Update #3229. | ||||
* | Update copyright notices. | Chris Johns | 2017-08-11 | 1 | -4/+7 |
* | c-user: Add support for references via bibtex | Sebastian Huber | 2017-01-18 | 1 | -0/+1 |
| | | | | | | https://sphinxcontrib-bibtex.readthedocs.io/en/latest/index.html Update #2871. | ||||
* | c-user: Add Ada support chapter | Joel Sherrill | 2017-01-17 | 1 | -0/+1 |
| | | | | closes #2589. | ||||
* | Update document titles for consistency | Joel Sherrill | 2017-01-11 | 1 | -5/+5 |
* | c-user: Format the directives as descriptions. | Chris Johns | 2016-11-08 | 1 | -1/+1 |
| | | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | ||||
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 1 | -0/+81 |
