2023-12-19 | glossary: Add terms | Sebastian Huber | 1 | -0/+54 | |
2023-07-25 | c-user: Link task entry and global construction | Sebastian Huber | 1 | -0/+13 | |
2023-07-20 | c-user: Add glossary terms for SPARC targets | Sebastian Huber | 1 | -0/+30 | |
2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2022-10-04 | c-user: Add application config info directives | Sebastian Huber | 1 | -4/+4 | |
Close #4267. Close #4269. | |||||
2022-07-26 | c-user: Do not mention pseudo-interrupt priority | Sebastian Huber | 1 | -2/+3 | |
Update #2365. | |||||
2021-09-30 | glossary: Add terms | Sebastian Huber | 1 | -0/+30 | |
2021-09-28 | glossary: Add OMIP | Sebastian Huber | 1 | -0/+6 | |
2021-09-15 | c-user: Fix use of lower and higher priority | Sebastian Huber | 1 | -2/+2 | |
2021-09-15 | c-user: Define lower and higher priority | Sebastian Huber | 1 | -5/+32 | |
2021-09-02 | c-user: Add LIFO to glossary | Sebastian Huber | 1 | -1/+9 | |
2021-05-12 | c-user: Add task priority glossary terms | Sebastian Huber | 1 | -3/+38 | |
2021-04-28 | c-user: Generate interrupt manager documentation | Sebastian Huber | 1 | -0/+5 | |
The documentation is a consolidation of the comments in Doxygen markup and the documentation sources in Sphinx markup. The documentation was transfered to interface specification items. The documentation source files were generated from the items by a script. Update #3993. | |||||
2021-04-27 | c-user: Fix wording for "home scheduler" | Sebastian Huber | 1 | -2/+2 | |
2021-04-21 | c-user: Add user extensions glossary terms | Sebastian Huber | 1 | -2/+38 | |
2021-04-14 | c-user: Add scheduler glossary terms | Sebastian Huber | 1 | -0/+24 | |
Add glossary terms which characterize the relationship of a scheduler to a task. | |||||
2021-02-17 | c-user: Generate clock manager documentation | Sebastian Huber | 1 | -0/+53 | |
2021-02-10 | c-user: Add control block acronyms | Sebastian Huber | 1 | -1/+13 | |
2020-06-30 | c-user: Add APA terms to glossary | Richi Dubey | 1 | -0/+28 | |
2020-06-04 | Use a complete sentence for acronym definitions | Sebastian Huber | 1 | -35/+36 | |
2020-04-01 | eng: Add glossary terms | Sebastian Huber | 1 | -6/+77 | |
Define the following terms: * assembler language * C language * ELF * interrupt service * software component * software unit Clarify: * task Update #3715. | |||||
2020-03-02 | eng: Add glossary | Sebastian Huber | 1 | -1/+50 | |
Update #3853. | |||||
2020-03-02 | c-user: Add copyrights to glossary | Sebastian Huber | 1 | -0/+3 | |
Use the file history to derive the copyright information. Update #3853. | |||||
2020-03-02 | c-user: Merge parition term definitions | Sebastian Huber | 1 | -4/+6 | |
2020-03-02 | c-user: Sort glossary terms | Sebastian Huber | 1 | -33/+33 | |
2020-03-02 | c-user: Clarify return code related terms | Sebastian Huber | 1 | -6/+12 | |
Remove duplicate "return code" definition. Add all related terms and use references. Update #3853. | |||||
2020-03-02 | c-user: Use four spaces per indent level | Sebastian Huber | 1 | -642/+642 | |
Four spaces per indent level is used in most files. Update #3853. | |||||
2020-02-27 | c-user: Canonicalize two glossary acronyms | Sebastian Huber | 1 | -2/+2 | |
Add :term: text roles to acronym definitions of glossary defined terms. Update #3853. | |||||
2020-02-24 | c-user: Rework glossary | Sebastian Huber | 1 | -13/+19 | |
Define exactly one term per definition. Use references for alternative terms. Add :term: text roles to acronym definitions of glossary defined terms. Update #3853. | |||||
2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 1 | -1/+1 | |
2018-04-30 | c-user: Fix typo | Sebastian Huber | 1 | -2/+2 | |
2017-02-03 | c-user: Update SMP introduction | Sebastian Huber | 1 | -3/+1 | |
2017-02-03 | c-user: Add TAS and TTAS terms | Sebastian Huber | 1 | -0/+6 | |
2017-02-02 | c-user: Add SMP low-level synchronization | Sebastian Huber | 1 | -0/+12 | |
2017-02-02 | c-user: Use sphinx glossary support | Sebastian Huber | 1 | -652/+652 | |
Terms can be referenced via :term:`XYZ`. | |||||
2017-02-02 | c-user: Add SMP application issues section | Sebastian Huber | 1 | -1/+18 | |
2017-02-01 | Use "in X config..." instead of "on X config..." | Sebastian Huber | 1 | -1/+1 | |
2017-02-01 | c-user: Add key concept thread queues | Sebastian Huber | 1 | -2/+10 | |
Update #2556. | |||||
2016-12-19 | Do not mention obsolete Giant lock | Sebastian Huber | 1 | -5/+0 | |
Close #2555. | |||||
2016-11-09 | c-user: Fix header levels. Minor fixes. | Chris Johns | 1 | -1/+1 | |
2016-11-03 | Update due to clock manager and driver changes | Sebastian Huber | 1 | -2/+2 | |
2016-11-03 | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 1 | -0/+0 | |
2016-10-28 | c_user: Remove errors and warnings. | Chris Johns | 1 | -1/+1 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 1 | -0/+2 | |
2016-05-02 | Clean up. | Chris Johns | 1 | -417/+320 | |
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 1 | -8/+8 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -4/+4 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -0/+833 | |
