path: root/c-user/glossary.rst (follow)
* c-user: Add scheduler glossary termsSebastian Huber2021-04-141-0/+24
| | | | | Add glossary terms which characterize the relationship of a scheduler to a task.
* c-user: Generate clock manager documentationSebastian Huber2021-02-171-0/+53
| | | | | | | | | The documentation is a consolidation of the comments in Doxygen markup and the documentation sources in Sphinx markup. The documentation was transfered to interface specification items. The documentation source files were generated from the items by a script. Update #3993.
* c-user: Add control block acronymsSebastian Huber2021-02-101-1/+13
| | | | Update #3993.
* c-user: Add APA terms to glossaryRichi Dubey2020-06-301-0/+28
* Use a complete sentence for acronym definitionsSebastian Huber2020-06-041-35/+36
* eng: Add glossary termsSebastian Huber2020-04-011-6/+77
| | | | | | | | | | | | | | | | | Define the following terms: * assembler language * C language * ELF * interrupt service * software component * software unit Clarify: * task Update #3715.
* eng: Add glossarySebastian Huber2020-03-021-1/+50
| | | | Update #3853.
* c-user: Add copyrights to glossarySebastian Huber2020-03-021-0/+3
| | | | | | Use the file history to derive the copyright information. Update #3853.
* c-user: Merge parition term definitionsSebastian Huber2020-03-021-4/+6
| | | | Update #3853.
* c-user: Sort glossary termsSebastian Huber2020-03-021-33/+33
| | | | Update #3853.
* c-user: Clarify return code related termsSebastian Huber2020-03-021-6/+12
| | | | | | | Remove duplicate "return code" definition. Add all related terms and use references. Update #3853.
* c-user: Use four spaces per indent levelSebastian Huber2020-03-021-642/+642
| | | | | | Four spaces per indent level is used in most files. Update #3853.
* c-user: Canonicalize two glossary acronymsSebastian Huber2020-02-271-2/+2
| | | | | | Add :term: text roles to acronym definitions of glossary defined terms. Update #3853.
* c-user: Rework glossarySebastian Huber2020-02-241-13/+19
| | | | | | | | Define exactly one term per definition. Use references for alternative terms. Add :term: text roles to acronym definitions of glossary defined terms. Update #3853.
* Simplify SPDX-License-Identifier commentSebastian Huber2019-01-111-1/+1
* c-user: Fix typoSebastian Huber2018-04-301-2/+2
* c-user: Update SMP introductionSebastian Huber2017-02-031-3/+1
* c-user: Add TAS and TTAS termsSebastian Huber2017-02-031-0/+6
* c-user: Add SMP low-level synchronizationSebastian Huber2017-02-021-0/+12
* c-user: Use sphinx glossary supportSebastian Huber2017-02-021-652/+652
| | | | Terms can be referenced via :term:`XYZ`.
* c-user: Add SMP application issues sectionSebastian Huber2017-02-021-1/+18
* Use "in X config..." instead of "on X config..."Sebastian Huber2017-02-011-1/+1
* c-user: Add key concept thread queuesSebastian Huber2017-02-011-2/+10
| | | | Update #2556.
* Do not mention obsolete Giant lockSebastian Huber2016-12-191-5/+0
| | | | Close #2555.
* c-user: Fix header levels. Minor fixes.Chris Johns2016-11-091-1/+1
* Update due to clock manager and driver changesSebastian Huber2016-11-031-2/+2
* Rename all manuals with an _ to have a -. It helps released naming of files.Chris Johns2016-11-031-0/+738
