* | c-user: Add user extensions glossary terms | Sebastian Huber | 2021-04-21 | 1 | -2/+38 |
* | c-user: Add scheduler glossary terms | Sebastian Huber | 2021-04-14 | 1 | -0/+24 |
| | | | | | Add glossary terms which characterize the relationship of a scheduler to a task. | ||||
* | c-user: Generate clock manager documentation | Sebastian Huber | 2021-02-17 | 1 | -0/+53 |
| | | | | | | | | | The documentation is a consolidation of the comments in Doxygen markup and the documentation sources in Sphinx markup. The documentation was transfered to interface specification items. The documentation source files were generated from the items by a script. Update #3993. | ||||
* | c-user: Add control block acronyms | Sebastian Huber | 2021-02-10 | 1 | -1/+13 |
* | c-user: Add APA terms to glossary | Richi Dubey | 2020-06-30 | 1 | -0/+28 |
* | Use a complete sentence for acronym definitions | Sebastian Huber | 2020-06-04 | 1 | -35/+36 |
* | eng: Add glossary terms | Sebastian Huber | 2020-04-01 | 1 | -6/+77 |
| | | | | | | | | | | | | | | | | | Define the following terms: * assembler language * C language * ELF * interrupt service * software component * software unit Clarify: * task Update #3715. | ||||
* | eng: Add glossary | Sebastian Huber | 2020-03-02 | 1 | -1/+50 |
| | | | | Update #3853. | ||||
* | c-user: Add copyrights to glossary | Sebastian Huber | 2020-03-02 | 1 | -0/+3 |
| | | | | | | Use the file history to derive the copyright information. Update #3853. | ||||
* | c-user: Merge parition term definitions | Sebastian Huber | 2020-03-02 | 1 | -4/+6 |
* | c-user: Sort glossary terms | Sebastian Huber | 2020-03-02 | 1 | -33/+33 |
* | c-user: Clarify return code related terms | Sebastian Huber | 2020-03-02 | 1 | -6/+12 |
| | | | | | | | Remove duplicate "return code" definition. Add all related terms and use references. Update #3853. | ||||
* | c-user: Use four spaces per indent level | Sebastian Huber | 2020-03-02 | 1 | -642/+642 |
| | | | | | | Four spaces per indent level is used in most files. Update #3853. | ||||
* | c-user: Canonicalize two glossary acronyms | Sebastian Huber | 2020-02-27 | 1 | -2/+2 |
| | | | | | | Add :term: text roles to acronym definitions of glossary defined terms. Update #3853. | ||||
* | c-user: Rework glossary | Sebastian Huber | 2020-02-24 | 1 | -13/+19 |
| | | | | | | | | Define exactly one term per definition. Use references for alternative terms. Add :term: text roles to acronym definitions of glossary defined terms. Update #3853. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | c-user: Fix typo | Sebastian Huber | 2018-04-30 | 1 | -2/+2 |
* | c-user: Update SMP introduction | Sebastian Huber | 2017-02-03 | 1 | -3/+1 |
* | c-user: Add TAS and TTAS terms | Sebastian Huber | 2017-02-03 | 1 | -0/+6 |
* | c-user: Add SMP low-level synchronization | Sebastian Huber | 2017-02-02 | 1 | -0/+12 |
* | c-user: Use sphinx glossary support | Sebastian Huber | 2017-02-02 | 1 | -652/+652 |
| | | | | Terms can be referenced via :term:`XYZ`. | ||||
* | c-user: Add SMP application issues section | Sebastian Huber | 2017-02-02 | 1 | -1/+18 |
* | Use "in X config..." instead of "on X config..." | Sebastian Huber | 2017-02-01 | 1 | -1/+1 |
* | c-user: Add key concept thread queues | Sebastian Huber | 2017-02-01 | 1 | -2/+10 |
| | | | | Update #2556. | ||||
* | Do not mention obsolete Giant lock | Sebastian Huber | 2016-12-19 | 1 | -5/+0 |
| | | | | Close #2555. | ||||
* | c-user: Fix header levels. Minor fixes. | Chris Johns | 2016-11-09 | 1 | -1/+1 |
* | Update due to clock manager and driver changes | Sebastian Huber | 2016-11-03 | 1 | -2/+2 |
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 1 | -0/+738 |
