index
rtems-docs
4.11
5
master
RTEMS Project documentation.
devel@rtems.org
summary
refs
log
tree
commit
diff
stats
log msg
author
committer
range
path:
root
c-user
glossary.rst
unfollow
Commit message (
Collapse
Author
Lines
2018-04-30
c-user: Fix typo
Sebastian Huber
1
-2
+2
2017-02-03
c-user: Update SMP introduction
Sebastian Huber
1
-3
+1
2017-02-03
c-user: Add TAS and TTAS terms
Sebastian Huber
1
-0
+6
2017-02-02
c-user: Add SMP low-level synchronization
Sebastian Huber
1
-0
+12
2017-02-02
c-user: Use sphinx glossary support
Sebastian Huber
1
-652
+652
Terms can be referenced via :term:`XYZ`.
2017-02-02
c-user: Add SMP application issues section
Sebastian Huber
1
-1
+18
2017-02-01
Use "in X config..." instead of "on X config..."
Sebastian Huber
1
-1
+1
2017-02-01
c-user: Add key concept thread queues
Sebastian Huber
1
-2
+10
Update #2556.
2016-12-19
Do not mention obsolete Giant lock
Sebastian Huber
1
-5
+0
Close #2555.
2016-11-09
c-user: Fix header levels. Minor fixes.
Chris Johns
1
-1
+1
2016-11-03
Update due to clock manager and driver changes
Sebastian Huber
1
-2
+2
2016-11-03
Rename all manuals with an _ to have a -. It helps released naming of files.
Chris Johns
1
-0
+0
2016-10-28
c_user: Remove errors and warnings.
Chris Johns
1
-1
+1
2016-05-20
Set SPDX License Identifier in each source file.
Chris Johns
1
-0
+2
2016-05-02
Clean up.
Chris Johns
1
-417
+320
2016-05-02
Convert all Unicode to ASCII(128)
Amar Takhar
1
-8
+8
2016-05-02
Split document into seperate files by section.
Amar Takhar
1
-4
+4
2016-05-02
Amar Takhar
1
-0
+833
