path: root/c-user/genindex.rst (follow)
* build: Fix indexing so it works on HTML and PDF.Chris Johns2018-08-211-4/+0
| | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503
* Add indexes to all documents.Chris Johns2017-11-121-0/+4
Update #3229.
