* | c-user: RTEMS_FATAL_SOURCE_INVALID_HEAP_FREE | Sebastian Huber | 2018-06-05 | 1 | -0/+4 |
| | | | | Close #3437. | ||||
* | fix typo: extesion->extension | Malte Münch | 2018-05-18 | 1 | -1/+1 |
* | c-user: Document global construction | Sebastian Huber | 2017-11-24 | 1 | -5/+0 |
| | | | | Close #3243. | ||||
* | c-user: Document rtems_panic() | Sebastian Huber | 2017-11-23 | 1 | -4/+42 |
| | | | | Close #3244. | ||||
* | Clarify INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAIL | Sebastian Huber | 2017-11-20 | 1 | -1/+2 |
| | | | | Update #3239. | ||||
* | Document INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAIL | Sebastian Huber | 2017-11-17 | 1 | -0/+4 |
| | | | | Close #3239. | ||||
* | INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT | Sebastian Huber | 2017-11-17 | 1 | -0/+4 |
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 1 | -8/+16 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | c-user: Fix index locations. | Chris Johns | 2017-11-12 | 1 | -20/+19 |
* | Use "in X config..." instead of "on X config..." | Sebastian Huber | 2017-02-01 | 1 | -3/+3 |
* | c-user: Rework user extensions chapter | Sebastian Huber | 2017-01-26 | 1 | -4/+4 |
| | | | | | Update #2692. Update #2752. | ||||
* | Update Initialization Manager chapter | Sebastian Huber | 2016-12-12 | 1 | -0/+36 |
| | | | | Update #2408. | ||||
* | Improve fatal error chapter | Sebastian Huber | 2016-12-12 | 1 | -33/+115 |
| | | | | Update #2825. | ||||
* | Improve fatal error chapter | Sebastian Huber | 2016-11-23 | 1 | -56/+120 |
* | Rework fatal error chapter | Sebastian Huber | 2016-11-21 | 1 | -85/+267 |
| | | | | Update #2811. | ||||
* | c-user: Fix header levels. Minor fixes. | Chris Johns | 2016-11-09 | 1 | -1/+1 |
* | c-user: Format the directives as descriptions. | Chris Johns | 2016-11-08 | 1 | -73/+72 |
| | | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | ||||
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 1 | -0/+253 |
