path: root/c-user/fatal_error.rst (follow)
* c-user: RTEMS_FATAL_SOURCE_INVALID_HEAP_FREESebastian Huber2018-06-051-0/+4
| | | | Close #3437.
* fix typo: extesion->extensionMalte Münch2018-05-181-1/+1
* c-user: Document global constructionSebastian Huber2017-11-241-5/+0
| | | | Close #3243.
* c-user: Document rtems_panic()Sebastian Huber2017-11-231-4/+42
| | | | Close #3244.
* Clarify INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAILSebastian Huber2017-11-201-1/+2
| | | | Update #3239.
* Document INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAILSebastian Huber2017-11-171-0/+4
| | | | Close #3239.
* INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNITSebastian Huber2017-11-171-0/+4
* Clean up sphinx warnings.Chris Johns2017-11-131-8/+16
| | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229.
* c-user: Fix index locations.Chris Johns2017-11-121-20/+19
| | | | Update #3229.
* Use "in X config..." instead of "on X config..."Sebastian Huber2017-02-011-3/+3
* c-user: Rework user extensions chapterSebastian Huber2017-01-261-4/+4
| | | | | Update #2692. Update #2752.
* Update Initialization Manager chapterSebastian Huber2016-12-121-0/+36
| | | | Update #2408.
* Improve fatal error chapterSebastian Huber2016-12-121-33/+115
| | | | Update #2825.
* Improve fatal error chapterSebastian Huber2016-11-231-56/+120
| | | | Update #2825.
* Rework fatal error chapterSebastian Huber2016-11-211-85/+267
| | | | Update #2811.
* c-user: Fix header levels. Minor fixes.Chris Johns2016-11-091-1/+1
* c-user: Format the directives as descriptions.Chris Johns2016-11-081-73/+72
| | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals.
* Rename all manuals with an _ to have a -. It helps released naming of files.Chris Johns2016-11-031-0/+253
