2020-09-02 | c-user: Split up event manager | Sebastian Huber | 1 | -309/+0 | |
This makes it easier to automatically generate parts of the manager documentation in the future. Update #3993. | |||||
2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 1 | -1/+1 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 1 | -1/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 1 | -2/+1 | |
2017-11-13 | Clean up sphinx warnings. | Chris Johns | 1 | -2/+4 | |
- Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | |||||
2017-11-12 | c-user: Fix index locations. | Chris Johns | 1 | -10/+12 | |
2016-11-09 | c-user: Fix header levels. Minor fixes. | Chris Johns | 1 | -1/+1 | |
2016-11-08 | c-user: Format the directives as descriptions. | Chris Johns | 1 | -104/+104 | |
This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | |||||
2016-11-03 | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 1 | -0/+0 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 1 | -0/+2 | |
2016-05-02 | Change code to code-block. | Chris Johns | 1 | -2/+2 | |
2016-05-02 | Clean ups. | Chris Johns | 1 | -168/+175 | |
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 1 | -5/+5 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -54/+56 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -0/+296 | |
