* | c-user: Rework clustered scheduling configuration | Sebastian Huber | 2018-03-07 | 1 | -149/+183 | |
* | c-user: Use uniprocessor throughout | Sebastian Huber | 2018-03-07 | 1 | -5/+5 | |
* | c-user: Sort scheduler configuration options | Sebastian Huber | 2018-03-07 | 1 | -96/+96 | |
* | c-user: Promote clustered scheduler configuration | Sebastian Huber | 2018-03-07 | 1 | -5/+5 | |
| | | | | Add own section for the clustered scheduler configuration. | |||||
* | c-user: Fix scheduler configuration overview | Sebastian Huber | 2018-03-07 | 1 | -4/+4 | |
* | c-user: Update CONFIGURE_SCHEDULER_NAME | Sebastian Huber | 2018-03-07 | 1 | -7/+9 | |
* | CONFIGURE_*_SIMPLE_TASK_CONSOLE_DRIVER | Sebastian Huber | 2018-03-06 | 1 | -13/+84 | |
| | | | | Update #3320. | |||||
* | CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER | Sebastian Huber | 2018-02-05 | 1 | -0/+39 | |
| | | | | | Close #3170. Update #3199. | |||||
* | c-user: Fix index directives | Sebastian Huber | 2018-02-05 | 1 | -0/+10 | |
| | | | | Update #3229. | |||||
* | c-user: Use configuration option as section name | Sebastian Huber | 2018-02-05 | 1 | -713/+390 | |
| | | | | | | | This makes it easier to find the documentation for a given configuration option. Remove superfluous comments. | |||||
* | c-user: Document obsolete termios config options | Sebastian Huber | 2018-02-05 | 1 | -63/+16 | |
| | | | | Update #2843. | |||||
* | c-user: Update unlimites objects configuration | Sebastian Huber | 2017-12-15 | 1 | -33/+22 | |
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 1 | -135/+267 | |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | |||||
* | c-user: Fix index locations. | Chris Johns | 2017-11-12 | 1 | -169/+169 | |
* | Change RTEMS version to 5 | Sebastian Huber | 2017-11-09 | 1 | -20/+20 | |
| | | | | Update #3220. | |||||
* | c-user/configuring_a_system.rst: Delete notepads section | Joel Sherrill | 2017-11-02 | 1 | -32/+0 | |
| | | | | closes #3215. | |||||
* | c-user: CONFIGURE_MAXIMUM_POSIX_SEMAPHORES | Sebastian Huber | 2017-10-12 | 1 | -6/+30 | |
| | | | | | | | This configuration is not obsolete since it is still used for named semaphores. Update #3116. | |||||
* | c-user: Add obsolete configuration options section | Sebastian Huber | 2017-10-09 | 1 | -164/+88 | |
| | | | | | | | | | Update #2493. Update #3112. Update #3113. Update #3114. Update #3115. Update #3116. | |||||
* | c-user: Clarify that confdefs.h is mandatory | Sebastian Huber | 2017-10-06 | 1 | -21/+3 | |
* | c-user: Document EDF SMP | Sebastian Huber | 2017-06-30 | 1 | -0/+27 | |
| | | | | Close #3056. | |||||
* | c-user: CONFIGURE_MAXIMUM_PROCESSORS | Sebastian Huber | 2017-02-14 | 1 | -40/+36 | |
| | | | | Update #2894. | |||||
* | c-user: Eliminate CONFIGURE_SMP_APPLICATION | Sebastian Huber | 2017-02-03 | 1 | -2/+2 | |
| | | | | Update #2893. | |||||
* | c-user: Update SMP introduction | Sebastian Huber | 2017-02-03 | 1 | -32/+1 | |
* | Use "in X config..." instead of "on X config..." | Sebastian Huber | 2017-02-01 | 1 | -4/+3 | |
* | c-user: Task names | Sebastian Huber | 2017-01-31 | 1 | -1/+1 | |
| | | | | Update #2858. | |||||
* | c-user: Update key concepts time | Sebastian Huber | 2017-01-30 | 1 | -1/+1 | |
* | c-user: Rework user extensions chapter | Sebastian Huber | 2017-01-26 | 1 | -1/+1 | |
| | | | | | Update #2692. Update #2752. | |||||
* | Document CONFIGURE_MAXIMUM_THREAD_NAME_SIZE | Sebastian Huber | 2017-01-13 | 1 | -0/+31 | |
* | CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS | Sebastian Huber | 2016-12-19 | 1 | -32/+0 | |
| | | | | | | | Do not mention obsolete CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS. Close #2702. | |||||
* | c-user: Document scheduler add/remove processor | Sebastian Huber | 2016-11-10 | 1 | -17/+25 | |
* | c-user: Fix header levels. Minor fixes. | Chris Johns | 2016-11-09 | 1 | -1/+1 | |
* | c-user: Format the directives as descriptions. | Chris Johns | 2016-11-08 | 1 | -1960/+1724 | |
| | | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | |||||
* | Update due to clock manager and driver changes | Sebastian Huber | 2016-11-03 | 1 | -1/+1 | |
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 1 | -0/+5345 | |
