* | c-user: Add event recording configuration | Sebastian Huber | 2019-02-01 | 1 | -0/+58 |
| | | | | Update #3665. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 1 | -1/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 1 | -2/+1 |
* | c-user: Use common wording for build config opts | Sebastian Huber | 2018-11-05 | 1 | -5/+5 |
* | c-user: Update POSIX API configuration | Sebastian Huber | 2018-11-05 | 1 | -11/+22 |
| | | | | Close ##2514. | ||||
* | Document CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS | Sebastian Huber | 2018-10-30 | 1 | -0/+32 |
* | c-user: Clarify scheduler configuration | Sebastian Huber | 2018-10-26 | 1 | -9/+48 |
* | c-user: Modify CONFIGURE_INTERRUPT_STACK_SIZE | Sebastian Huber | 2018-10-22 | 1 | -12/+29 |
| | | | | | | | | | Use CPU_STACK_MINIMUM_SIZE instead of CONFIGURE_MINIMUM_TASK_STACK_SIZE to set the default value. Clarify documentation. Update #3480. | ||||
* | Remove CONFIGURE_HAS_OWN_CONFIGURATION_TABLE | Sebastian Huber | 2018-09-17 | 1 | -26/+7 |
| | | | | | Close #3489. Close #3490. | ||||
* | c-user: Remove CONFIGURE_HAS_OWN_MOUNT_TABLE | Sebastian Huber | 2018-09-17 | 1 | -33/+7 |
| | | | | Close #3488. | ||||
* | c-user: CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE | Sebastian Huber | 2018-08-07 | 1 | -7/+37 |
| | | | | Close #3434. | ||||
* | c-user: Sort POSIX configuration options | Sebastian Huber | 2018-08-07 | 1 | -60/+60 |
* | configuring_a_system.rst, scheduling_concepts.rst: Fix spelling of arbitrary. | Joel Sherrill | 2018-05-23 | 1 | -1/+1 |
* | c-user/configuring_a_system.rst: Removed double 'with' | Malte Münch | 2018-05-18 | 1 | -1/+1 |
* | c-user: Properly fix the previous typo | Sebastian Huber | 2018-03-12 | 1 | -1/+1 |
* | c-user: Fix typo | Sebastian Huber | 2018-03-12 | 1 | -1/+1 |
* | c-user: Simplify clustered scheduler configuration | Sebastian Huber | 2018-03-12 | 1 | -45/+54 |
| | | | | Close #3325. | ||||
* | c-user: Rework scheduler alogrithm config defs | Sebastian Huber | 2018-03-08 | 1 | -78/+92 |
| | | | | Update #3325. | ||||
* | c-user: Rework clustered scheduling configuration | Sebastian Huber | 2018-03-07 | 1 | -149/+183 |
* | c-user: Use uniprocessor throughout | Sebastian Huber | 2018-03-07 | 1 | -5/+5 |
* | c-user: Sort scheduler configuration options | Sebastian Huber | 2018-03-07 | 1 | -96/+96 |
* | c-user: Promote clustered scheduler configuration | Sebastian Huber | 2018-03-07 | 1 | -5/+5 |
| | | | | Add own section for the clustered scheduler configuration. | ||||
* | c-user: Fix scheduler configuration overview | Sebastian Huber | 2018-03-07 | 1 | -4/+4 |
* | c-user: Update CONFIGURE_SCHEDULER_NAME | Sebastian Huber | 2018-03-07 | 1 | -7/+9 |
* | CONFIGURE_*_SIMPLE_TASK_CONSOLE_DRIVER | Sebastian Huber | 2018-03-06 | 1 | -13/+84 |
| | | | | Update #3320. | ||||
* | CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER | Sebastian Huber | 2018-02-05 | 1 | -0/+39 |
| | | | | | Close #3170. Update #3199. | ||||
* | c-user: Fix index directives | Sebastian Huber | 2018-02-05 | 1 | -0/+10 |
| | | | | Update #3229. | ||||
* | c-user: Use configuration option as section name | Sebastian Huber | 2018-02-05 | 1 | -713/+390 |
| | | | | | | | This makes it easier to find the documentation for a given configuration option. Remove superfluous comments. | ||||
* | c-user: Document obsolete termios config options | Sebastian Huber | 2018-02-05 | 1 | -63/+16 |
| | | | | Update #2843. | ||||
* | c-user: Update unlimites objects configuration | Sebastian Huber | 2017-12-15 | 1 | -33/+22 |
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 1 | -135/+267 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | c-user: Fix index locations. | Chris Johns | 2017-11-12 | 1 | -169/+169 |
* | Change RTEMS version to 5 | Sebastian Huber | 2017-11-09 | 1 | -20/+20 |
| | | | | Update #3220. | ||||
* | c-user/configuring_a_system.rst: Delete notepads section | Joel Sherrill | 2017-11-02 | 1 | -32/+0 |
| | | | | closes #3215. | ||||
* | c-user: CONFIGURE_MAXIMUM_POSIX_SEMAPHORES | Sebastian Huber | 2017-10-12 | 1 | -6/+30 |
| | | | | | | | This configuration is not obsolete since it is still used for named semaphores. Update #3116. | ||||
* | c-user: Add obsolete configuration options section | Sebastian Huber | 2017-10-09 | 1 | -164/+88 |
| | | | | | | | | | Update #2493. Update #3112. Update #3113. Update #3114. Update #3115. Update #3116. | ||||
* | c-user: Clarify that confdefs.h is mandatory | Sebastian Huber | 2017-10-06 | 1 | -21/+3 |
* | c-user: Document EDF SMP | Sebastian Huber | 2017-06-30 | 1 | -0/+27 |
| | | | | Close #3056. | ||||
* | c-user: CONFIGURE_MAXIMUM_PROCESSORS | Sebastian Huber | 2017-02-14 | 1 | -40/+36 |
| | | | | Update #2894. | ||||
* | c-user: Eliminate CONFIGURE_SMP_APPLICATION | Sebastian Huber | 2017-02-03 | 1 | -2/+2 |
| | | | | Update #2893. | ||||
* | c-user: Update SMP introduction | Sebastian Huber | 2017-02-03 | 1 | -32/+1 |
* | Use "in X config..." instead of "on X config..." | Sebastian Huber | 2017-02-01 | 1 | -4/+3 |
* | c-user: Task names | Sebastian Huber | 2017-01-31 | 1 | -1/+1 |
| | | | | Update #2858. | ||||
* | c-user: Update key concepts time | Sebastian Huber | 2017-01-30 | 1 | -1/+1 |
* | c-user: Rework user extensions chapter | Sebastian Huber | 2017-01-26 | 1 | -1/+1 |
| | | | | | Update #2692. Update #2752. | ||||
* | Document CONFIGURE_MAXIMUM_THREAD_NAME_SIZE | Sebastian Huber | 2017-01-13 | 1 | -0/+31 |
* | CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS | Sebastian Huber | 2016-12-19 | 1 | -32/+0 |
| | | | | | | | Do not mention obsolete CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS. Close #2702. | ||||
* | c-user: Document scheduler add/remove processor | Sebastian Huber | 2016-11-10 | 1 | -17/+25 |
* | c-user: Fix header levels. Minor fixes. | Chris Johns | 2016-11-09 | 1 | -1/+1 |
