2019-04-09 | c-user: Obsolete Go configuration options | Sebastian Huber | 1 | -81/+21 | |
Update #2832. | |||||
2019-02-08 | Add copyright notices | Sebastian Huber | 1 | -0/+2 | |
2019-02-01 | c-user: Add event recording configuration | Sebastian Huber | 1 | -0/+58 | |
Update #3665. | |||||
2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 1 | -1/+1 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 1 | -1/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 1 | -2/+1 | |
2018-11-05 | c-user: Use common wording for build config opts | Sebastian Huber | 1 | -5/+5 | |
2018-11-05 | c-user: Update POSIX API configuration | Sebastian Huber | 1 | -11/+22 | |
Close ##2514. | |||||
2018-10-30 | Document CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS | Sebastian Huber | 1 | -0/+32 | |
2018-10-26 | c-user: Clarify scheduler configuration | Sebastian Huber | 1 | -9/+48 | |
2018-10-22 | c-user: Modify CONFIGURE_INTERRUPT_STACK_SIZE | Sebastian Huber | 1 | -12/+29 | |
Use CPU_STACK_MINIMUM_SIZE instead of CONFIGURE_MINIMUM_TASK_STACK_SIZE to set the default value. Clarify documentation. Update #3480. | |||||
2018-09-17 | Remove CONFIGURE_HAS_OWN_CONFIGURATION_TABLE | Sebastian Huber | 1 | -26/+7 | |
Close #3489. Close #3490. | |||||
2018-09-17 | c-user: Remove CONFIGURE_HAS_OWN_MOUNT_TABLE | Sebastian Huber | 1 | -33/+7 | |
Close #3488. | |||||
2018-08-07 | c-user: CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE | Sebastian Huber | 1 | -7/+37 | |
Close #3434. | |||||
2018-08-07 | c-user: Sort POSIX configuration options | Sebastian Huber | 1 | -60/+60 | |
2018-05-23 | configuring_a_system.rst, scheduling_concepts.rst: Fix spelling of arbitrary. | Joel Sherrill | 1 | -1/+1 | |
2018-05-18 | c-user/configuring_a_system.rst: Removed double 'with' | Malte Münch | 1 | -1/+1 | |
2018-03-12 | c-user: Properly fix the previous typo | Sebastian Huber | 1 | -1/+1 | |
2018-03-12 | c-user: Fix typo | Sebastian Huber | 1 | -1/+1 | |
2018-03-12 | c-user: Simplify clustered scheduler configuration | Sebastian Huber | 1 | -45/+54 | |
Close #3325. | |||||
2018-03-08 | c-user: Rework scheduler alogrithm config defs | Sebastian Huber | 1 | -78/+92 | |
Update #3325. | |||||
2018-03-07 | c-user: Rework clustered scheduling configuration | Sebastian Huber | 1 | -149/+183 | |
2018-03-07 | c-user: Use uniprocessor throughout | Sebastian Huber | 1 | -5/+5 | |
2018-03-07 | c-user: Sort scheduler configuration options | Sebastian Huber | 1 | -96/+96 | |
2018-03-07 | c-user: Promote clustered scheduler configuration | Sebastian Huber | 1 | -5/+5 | |
Add own section for the clustered scheduler configuration. | |||||
2018-03-07 | c-user: Fix scheduler configuration overview | Sebastian Huber | 1 | -4/+4 | |
2018-03-07 | c-user: Update CONFIGURE_SCHEDULER_NAME | Sebastian Huber | 1 | -7/+9 | |
2018-03-06 | CONFIGURE_*_SIMPLE_TASK_CONSOLE_DRIVER | Sebastian Huber | 1 | -13/+84 | |
Update #3320. | |||||
2018-02-05 | CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER | Sebastian Huber | 1 | -0/+39 | |
Close #3170. Update #3199. | |||||
2018-02-05 | c-user: Fix index directives | Sebastian Huber | 1 | -0/+10 | |
Update #3229. | |||||
2018-02-05 | c-user: Use configuration option as section name | Sebastian Huber | 1 | -713/+390 | |
This makes it easier to find the documentation for a given configuration option. Remove superfluous comments. | |||||
2018-02-05 | c-user: Document obsolete termios config options | Sebastian Huber | 1 | -63/+16 | |
Update #2843. | |||||
2017-12-15 | c-user: Update unlimites objects configuration | Sebastian Huber | 1 | -33/+22 | |
2017-11-13 | Clean up sphinx warnings. | Chris Johns | 1 | -135/+267 | |
- Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | |||||
2017-11-12 | c-user: Fix index locations. | Chris Johns | 1 | -169/+169 | |
2017-11-09 | Change RTEMS version to 5 | Sebastian Huber | 1 | -20/+20 | |
Update #3220. | |||||
2017-11-02 | c-user/configuring_a_system.rst: Delete notepads section | Joel Sherrill | 1 | -32/+0 | |
closes #3215. | |||||
2017-10-12 | c-user: CONFIGURE_MAXIMUM_POSIX_SEMAPHORES | Sebastian Huber | 1 | -6/+30 | |
This configuration is not obsolete since it is still used for named semaphores. Update #3116. | |||||
2017-10-09 | c-user: Add obsolete configuration options section | Sebastian Huber | 1 | -164/+88 | |
Update #2493. Update #3112. Update #3113. Update #3114. Update #3115. Update #3116. | |||||
2017-10-06 | c-user: Clarify that confdefs.h is mandatory | Sebastian Huber | 1 | -21/+3 | |
2017-06-30 | c-user: Document EDF SMP | Sebastian Huber | 1 | -0/+27 | |
Close #3056. | |||||
2017-02-14 | c-user: CONFIGURE_MAXIMUM_PROCESSORS | Sebastian Huber | 1 | -40/+36 | |
Update #2894. | |||||
2017-02-03 | c-user: Eliminate CONFIGURE_SMP_APPLICATION | Sebastian Huber | 1 | -2/+2 | |
Update #2893. | |||||
2017-02-03 | c-user: Update SMP introduction | Sebastian Huber | 1 | -32/+1 | |
2017-02-01 | Use "in X config..." instead of "on X config..." | Sebastian Huber | 1 | -4/+3 | |
2017-01-31 | c-user: Task names | Sebastian Huber | 1 | -1/+1 | |
Update #2858. | |||||
2017-01-30 | c-user: Update key concepts time | Sebastian Huber | 1 | -1/+1 | |
2017-01-26 | c-user: Rework user extensions chapter | Sebastian Huber | 1 | -1/+1 | |
Update #2692. Update #2752. | |||||
2017-01-13 | Document CONFIGURE_MAXIMUM_THREAD_NAME_SIZE | Sebastian Huber | 1 | -0/+31 | |
2016-12-19 | CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS | Sebastian Huber | 1 | -32/+0 | |
Do not mention obsolete CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS. Close #2702. |
