2016-11-09 | c-user: Fix header levels. Minor fixes. | Chris Johns | 1 | -1/+1 | |
2016-11-08 | c-user: Format the directives as descriptions. | Chris Johns | 1 | -1960/+1724 | |
This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | |||||
2016-11-03 | Update due to clock manager and driver changes | Sebastian Huber | 1 | -1/+1 | |
2016-11-03 | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 1 | -0/+0 | |
2016-11-01 | c_user: Re-add task notepads for 4.11. Remove this patch after branching. | Joel Sherrill | 1 | -0/+32 | |
2016-10-28 | c_user: Fix numbered lists. | Joel Sherrill | 1 | -2/+2 | |
2016-10-28 | c_user: Remove errors and warnings. | Chris Johns | 1 | -5/+290 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 1 | -0/+2 | |
2016-05-02 | Minor fixes. | Chris Johns | 1 | -4/+4 | |
2016-05-02 | Change code to code-block. | Chris Johns | 1 | -7/+7 | |
2016-05-02 | Fix the double quotes. | Chris Johns | 1 | -4/+4 | |
2016-05-02 | Clean up | Chris Johns | 1 | -972/+982 | |
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 1 | -14/+14 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -51/+41 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -0/+5026 | |
