* | c-user: Add "Generated from ..." comments | Sebastian Huber | 2020-11-09 | 1 | -0/+10 |
* | Improve file header comment in generated files | Sebastian Huber | 2020-10-11 | 1 | -4/+9 |
* | c-user: Add automatically generated warning | Sebastian Huber | 2020-08-07 | 1 | -0/+7 |
| | | | | Update #3994. | ||||
* | c-user: Improve refs and formatting in appl config | Sebastian Huber | 2020-08-07 | 1 | -1/+1 |
| | | | | | | The formatting is generated through references within the specification. Update #3994. | ||||
* | c-user: Use new template for integer config opts | Sebastian Huber | 2020-04-01 | 1 | -10/+22 |
| | | | | | | | | | Try to bring all descriptions up to date. Add cross-references to several options. Clarify configuration value constraints. Use this template also for initializer type options. Close #3901. | ||||
* | c-user: Document new event record config options | Sebastian Huber | 2020-03-24 | 1 | -1/+64 |
| | | | | Update #3904. | ||||
* | c-user: Use new template for feature config opts | Sebastian Huber | 2020-03-24 | 1 | -13/+15 |
| | | | | | | | Try to bring all descriptions up to date. Add cross-references to several options. Close #3900. | ||||
* | c-user: Canonicalize configuration option groups | Sebastian Huber | 2020-03-18 | 1 | -0/+2 |
| | | | | Update #3836. | ||||
* | c-user: Move "Event Recording Configuration" | Sebastian Huber | 2020-03-12 | 1 | -0/+61 |
Update #3836. |
