* | c-user: Reformat configuration option constraints | Sebastian Huber | 2021-04-29 | 1 | -85/+91 |
| | | | | | | If only one constraint is present, then use a single sentence, otherwise use a list for the constraints. Format the constraints so that the line length limit is maintained. | ||||
* | c-user: Clarify constraints | Sebastian Huber | 2021-03-08 | 1 | -2/+8 |
* | Improve file header comment in generated files | Sebastian Huber | 2021-01-25 | 1 | -3/+7 |
* | Improve automatically generated warning | Sebastian Huber | 2020-11-12 | 1 | -5/+4 |
* | c-user: Add "Generated from ..." comments | Sebastian Huber | 2020-11-09 | 1 | -0/+26 |
* | Improve file header comment in generated files | Sebastian Huber | 2020-10-11 | 1 | -4/+9 |
* | c-user: CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE | Sebastian Huber | 2020-09-17 | 1 | -0/+32 |
| | | | | | | Document this application configuration option. Update #3959. | ||||
* | c-user: CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE | Sebastian Huber | 2020-09-17 | 1 | -0/+44 |
| | | | | | | Document this application configuration option. Close #4074. | ||||
* | c-user: Add automatically generated warning | Sebastian Huber | 2020-08-07 | 1 | -0/+7 |
| | | | | Update #3994. | ||||
* | c-user: Improve refs and formatting in appl config | Sebastian Huber | 2020-08-07 | 1 | -1/+1 |
| | | | | | | The formatting is generated through references within the specification. Update #3994. | ||||
* | c-user: Unify references in appl config chapter | Sebastian Huber | 2020-07-23 | 1 | -5/+2 |
| | | | | | This is a prepration step to allow the generation of the application configuration options in Doxygen markup. | ||||
* | c-user: Use new template for integer config opts | Sebastian Huber | 2020-04-01 | 1 | -84/+233 |
| | | | | | | | | | Try to bring all descriptions up to date. Add cross-references to several options. Clarify configuration value constraints. Use this template also for initializer type options. Close #3901. | ||||
* | c-user: Canonicalize configuration option groups | Sebastian Huber | 2020-03-18 | 1 | -2/+1 |
| | | | | Update #3836. | ||||
* | c-user: Move "Classic API Configuration" | Sebastian Huber | 2020-03-12 | 1 | -0/+291 |
Update #3836. |
