* | c-user: Reformat configuration option constraints | Sebastian Huber | 2021-04-29 | 1 | -11/+11 |
| | | | | | | If only one constraint is present, then use a single sentence, otherwise use a list for the constraints. Format the constraints so that the line length limit is maintained. | ||||
* | c-user: CONFIGURE_BSP_PREREQUISITE_DRIVERS | Sebastian Huber | 2021-04-29 | 1 | -2/+2 |
| | | | | Replace copy and paste with a proper description. | ||||
* | Improve file header comment in generated files | Sebastian Huber | 2021-01-25 | 1 | -3/+7 |
* | Improve automatically generated warning | Sebastian Huber | 2020-11-12 | 1 | -5/+4 |
* | c-user: Add "Generated from ..." comments | Sebastian Huber | 2020-11-09 | 1 | -0/+16 |
* | Improve file header comment in generated files | Sebastian Huber | 2020-10-11 | 1 | -4/+9 |
* | c-user: Add automatically generated warning | Sebastian Huber | 2020-08-07 | 1 | -0/+7 |
| | | | | Update #3994. | ||||
* | c-user: Improve refs and formatting in appl config | Sebastian Huber | 2020-08-07 | 1 | -6/+6 |
| | | | | | | The formatting is generated through references within the specification. Update #3994. | ||||
* | c-user: Fix appl config option references | Sebastian Huber | 2020-07-06 | 1 | -1/+1 |
* | c-user: Use * for list items | Sebastian Huber | 2020-06-17 | 1 | -6/+6 |
* | c-user: Use new template for integer config opts | Sebastian Huber | 2020-04-01 | 1 | -85/+94 |
| | | | | | | | | | Try to bring all descriptions up to date. Add cross-references to several options. Clarify configuration value constraints. Use this template also for initializer type options. Close #3901. | ||||
* | c-user: Use new template for feature config opts | Sebastian Huber | 2020-03-30 | 1 | -23/+35 |
| | | | | Update #3900. | ||||
* | c-user: Fix typo in file name | Sebastian Huber | 2020-03-30 | 1 | -0/+247 |
Update #3836. |
