path: root/c-user/clock_manager.rst (follow)
* Simplify SPDX-License-Identifier commentSebastian Huber2019-01-111-1/+1
* Remove superfluous "All rights reserved."Sebastian Huber2019-01-111-1/+0
* Use standard format for copyright linesSebastian Huber2019-01-111-2/+1
* Clean up sphinx warnings.Chris Johns2017-11-131-2/+2
| | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229.
* c-user: Fix index locations.Chris Johns2017-11-121-28/+44
| | | | Update #3229.
* c-user: Update to reflect rtems_clock_get() being obsoleted.Joel Sherrill2017-10-111-94/+22
| | | | Closes #2693.
* c-user: Fix header levels. Minor fixes.Chris Johns2016-11-091-2/+1
* c-user: Format the directives as descriptions.Chris Johns2016-11-081-314/+316
| | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals.
* Update due to clock manager and driver changesSebastian Huber2016-11-031-97/+15
* Rename all manuals with an _ to have a -. It helps released naming of files.Chris Johns2016-11-031-0/+807
