* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 1 | -2/+2 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | c-user: Fix index locations. | Chris Johns | 2017-11-12 | 1 | -28/+44 |
* | c-user: Update to reflect rtems_clock_get() being obsoleted. | Joel Sherrill | 2017-10-11 | 1 | -94/+22 |
| | | | | Closes #2693. | ||||
* | c-user: Fix header levels. Minor fixes. | Chris Johns | 2016-11-09 | 1 | -2/+1 |
* | c-user: Format the directives as descriptions. | Chris Johns | 2016-11-08 | 1 | -314/+316 |
| | | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | ||||
* | Update due to clock manager and driver changes | Sebastian Huber | 2016-11-03 | 1 | -97/+15 |
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 1 | -0/+807 |
