2017-11-13 | Clean up sphinx warnings. | Chris Johns | 1 | -2/+2 | |
- Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | |||||
2017-11-12 | c-user: Fix index locations. | Chris Johns | 1 | -47/+71 | |
2016-11-09 | c-user: Fix header levels. Minor fixes. | Chris Johns | 1 | -1/+1 | |
2016-11-08 | c-user: Format the directives as descriptions. | Chris Johns | 1 | -343/+327 | |
This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | |||||
2016-11-03 | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 1 | -0/+0 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 1 | -0/+2 | |
2016-05-02 | Clean up. | Chris Johns | 1 | -207/+359 | |
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 1 | -5/+5 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -48/+209 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -0/+558 | |
