2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2023-05-09 | c-user: Generate API type documentation | Sebastian Huber | 1 | -6/+6 | |
Close #4901. | |||||
2021-06-15 | c-user: Use a common phrase for pointer parameters | Sebastian Huber | 1 | -7/+8 | |
Mention the type of the pointer in the parameter description. Use the more general term "object" instead of "variable". Update #3993. | |||||
2021-04-28 | c-user: Clarify constraints | Sebastian Huber | 1 | -1/+2 | |
2021-02-10 | c-user: Generate barrier manager documentation | Sebastian Huber | 1 | -209/+357 | |
The documentation is a consolidation of the comments in Doxygen markup and the documentation sources in Sphinx markup. The documentation was transfered to interface specification items. The documentation source files were generated from the items by a script. Update #3993. | |||||
2020-09-02 | c-user: Split up barrier manager | Sebastian Huber | 1 | -158/+11 | |
This makes it easier to automatically generate parts of the manager documentation in the future. Update #3993. | |||||
2020-06-18 | c-user: Mention possible preemptions | Sebastian Huber | 1 | -1/+5 | |
Mention that object create/delete may case the calling task to be preempted due to the object allocator mutex. | |||||
2019-11-06 | barrier: Reword "forever" -> "until [..] released" | Martin Erik Werner | 1 | -1/+1 | |
2019-11-06 | barrier: Remove more semaphore leftovers | Martin Erik Werner | 1 | -2/+1 | |
Remove another mention of options which is available for semaphore but not for barriers. | |||||
2019-11-06 | barrier: Fix cticket->ticket typo | Martin Erik Werner | 1 | -2/+2 | |
2019-11-06 | barrier: Remove unfinished sentence | Martin Erik Werner | 1 | -4/+3 | |
Remove the unfinished sentence "Since a barrier is, by definition, never immediately [...]" and jump directly to "The task may wait [forever or for a timeout]" instead. I cannot figure out what the unfinished sentence is supposed to be - "released"? "passed"? | |||||
2019-11-06 | barrier: Remove leftover semaphore remnants | Martin Erik Werner | 1 | -31/+7 | |
Remove various incorrect references to "lock" and "obtain" and to an option set which is not part of the barrier interface. It looks like the barrier documentation was started based on a copy of the semaphore documentation and these things are surviving remnants. Also remove an unfinished sentence in the barrier wait description, since the intended information is already provided in the under the NOTE label. | |||||
2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 1 | -1/+1 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 1 | -1/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 1 | -1/+1 | |
2018-10-05 | barrier_manager.rst: Fix Barrier Wait Section Title | Joel Sherrill | 1 | -2/+2 | |
closes #3538. | |||||
2017-11-20 | Mention barrier manager in rtems_semaphore_flush() | Sebastian Huber | 1 | -0/+2 | |
2017-11-12 | c-user: Fix index locations. | Chris Johns | 1 | -12/+17 | |
Update #3229. | |||||
2016-11-09 | c-user: Fix header levels. Minor fixes. | Chris Johns | 1 | -1/+1 | |
2016-11-08 | c-user: Format the directives as descriptions. | Chris Johns | 1 | -196/+195 | |
This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | |||||
2016-11-03 | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 1 | -0/+0 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 1 | -0/+2 | |
2016-05-02 | Change code to code-block. | Chris Johns | 1 | -5/+5 | |
2016-05-02 | Fix the double quotes. | Chris Johns | 1 | -4/+4 | |
2016-05-02 | Clean ups. | Chris Johns | 1 | -194/+227 | |
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 1 | -9/+9 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -73/+78 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -0/+389 | |
