* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 23 | -4656/+0 |
* | Remove the old files. | Chris Johns | 2016-10-29 | 1 | -4580/+0 |
* | makefiles.rst, target_dependant_files.rst: Fix link | Joel Sherrill | 2016-10-28 | 2 | -1/+3 |
* | target_dependant_files.rst: Fix spacing and warning. | Joel Sherrill | 2016-10-28 | 1 | -1/+1 |
* | initilization_code.rst, linker_script.rst: Fix cross reference | Joel Sherrill | 2016-10-28 | 2 | -1/+3 |
* | bsp_howto: Fix ASCII figure. | Chris Johns | 2016-10-28 | 1 | -11/+11 |
* | bsp_howto: Fix code-block markup | Joel Sherrill | 2016-10-27 | 6 | -21/+21 |
* | rtems-docs: Fix many unnecessary back slashes | Joel Sherrill | 2016-10-27 | 2 | -9/+9 |
* | initilization_code.rst: Fix figure formatting | Joel Sherrill | 2016-10-27 | 1 | -7/+7 |
* | Misc: Capitalize RTEMS. | Joel Sherrill | 2016-10-27 | 2 | -4/+4 |
* | Update the BSP howto. | Chris Johns | 2016-06-17 | 21 | -2629/+2680 |
| | | | | Closes #2590. | ||||
* | Set SPDX License Identifier in each source file. | Chris Johns | 2016-05-20 | 22 | -0/+44 |
* | Add 'waf linkcheck' to check external references. | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
* | Add PDF generation support use with --pdf | Amar Takhar | 2016-05-02 | 2 | -6/+5 |
* | Add support for spellchecking with a custom dictionary. | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
| | | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | ||||
* | Convert all Unicode to ASCII(128) | Amar Takhar | 2016-05-02 | 16 | -50/+50 |
* | Rework how conf.py is handled. | Amar Takhar | 2016-05-02 | 2 | -9/+9 |
| | | | | Needed to switch due to increasing complexity. | ||||
* | Rename old document for reference only. | Amar Takhar | 2016-05-02 | 1 | -0/+0 |
* | Split document into seperate files by section. | Amar Takhar | 2016-05-02 | 21 | -1/+4541 |
* | Fix warnings. | Amar Takhar | 2016-05-02 | 1 | -33/+81 |
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 3 | -0/+4550 |
