2016-10-28 | makefiles.rst, target_dependant_files.rst: Fix link | Joel Sherrill | 2 | -1/+3 | |
2016-10-28 | target_dependant_files.rst: Fix spacing and warning. | Joel Sherrill | 1 | -1/+1 | |
2016-10-28 | initilization_code.rst, linker_script.rst: Fix cross reference | Joel Sherrill | 2 | -1/+3 | |
2016-10-28 | bsp_howto: Fix ASCII figure. | Chris Johns | 1 | -11/+11 | |
2016-10-27 | bsp_howto: Fix code-block markup | Joel Sherrill | 6 | -21/+21 | |
2016-10-27 | rtems-docs: Fix many unnecessary back slashes | Joel Sherrill | 2 | -9/+9 | |
2016-10-27 | initilization_code.rst: Fix figure formatting | Joel Sherrill | 1 | -7/+7 | |
2016-10-27 | Misc: Capitalize RTEMS. | Joel Sherrill | 2 | -4/+4 | |
2016-06-17 | Update the BSP howto. | Chris Johns | 21 | -2629/+2680 | |
Closes #2590. | |||||
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 22 | -0/+44 | |
2016-05-02 | Add 'waf linkcheck' to check external references. | Amar Takhar | 1 | -1/+1 | |
2016-05-02 | Add PDF generation support use with --pdf | Amar Takhar | 2 | -6/+5 | |
2016-05-02 | Add support for spellchecking with a custom dictionary. | Amar Takhar | 1 | -1/+1 | |
To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | |||||
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 16 | -50/+50 | |
2016-05-02 | Rework how conf.py is handled. | Amar Takhar | 2 | -9/+9 | |
Needed to switch due to increasing complexity. | |||||
2016-05-02 | Rename old document for reference only. | Amar Takhar | 1 | -0/+0 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 21 | -1/+4541 | |
2016-05-02 | Fix warnings. | Amar Takhar | 1 | -33/+81 | |
