* | Add warning to Timer Driver chapter | Sebastian Huber | 2016-12-21 | 2 | -1/+6 | |
| | | | | | | Move Timer Driver chapter. Update #2847. | |||||
* | Add warning to ATA/IDE driver chapter | Sebastian Huber | 2016-12-21 | 3 | -2/+16 | |
| | | | | Close #2849. | |||||
* | Remove Non-Volatile Memory Driver chapter | Sebastian Huber | 2016-12-21 | 2 | -218/+0 | |
| | | | | | | | There exists no standard Non-Volatile Memory Driver in the RTEMS code base. Close #2851. | |||||
* | Remove Discrete Driver chapter | Sebastian Huber | 2016-12-21 | 2 | -191/+0 | |
| | | | | | | There exists no standard Discrete Driver in the RTEMS code base. Close #2851. | |||||
* | Remove Analog Driver chapter | Sebastian Huber | 2016-12-21 | 2 | -166/+0 | |
| | | | | | | There exists no standard Analog Driver in the RTEMS code base. Close #2850. | |||||
* | Document I2C framework | Sebastian Huber | 2016-12-21 | 2 | -0/+20 | |
| | | | | Update #2845. | |||||
* | Document SPI framework | Sebastian Huber | 2016-12-21 | 2 | -0/+20 | |
| | | | | Update #2776. | |||||
* | Update version/revision to 4.11.99 | Sebastian Huber | 2016-12-21 | 1 | -2/+2 | |
* | Rework Clock Driver chapter | Sebastian Huber | 2016-12-21 | 1 | -100/+137 | |
| | | | | Update #2737. | |||||
* | bsp-howto: Increase the number depth of sections. | Chris Johns | 2016-11-09 | 1 | -1/+1 | |
* | bsp-howto: Fix header levels. | Chris Johns | 2016-11-09 | 20 | -23/+22 | |
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 23 | -0/+4656 | |
