2019-01-31 | bsp-howto: Fix URLs | Sebastian Huber | 2 | -2/+2 | |
2019-01-14 | Reformat and update copyright and license notices | Sebastian Huber | 1 | -8/+8 | |
For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | |||||
2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 20 | -20/+20 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 18 | -18/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 18 | -33/+18 | |
2019-01-09 | Add common header.rst to reduce copy and paste | Sebastian Huber | 1 | -23/+1 | |
2018-10-19 | Update the copyright year. | Chris Johns | 1 | -1/+1 | |
2018-08-21 | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2 | -5/+1 | |
- Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | |||||
2018-06-26 | bsp-howto: Mention clock driver hook removal | Sebastian Huber | 1 | -22/+1 | |
Update #3436. | |||||
2018-04-27 | Update due to BSP source reorganization | Sebastian Huber | 13 | -355/+74 | |
This patch is a part of the BSP source reorganization. Close #3285. | |||||
2018-04-23 | bsp-howto: Avoid :file: role with ${...} | Sebastian Huber | 1 | -4/+4 | |
The curly braces have a special meaning in the :file: role. This patch is a part of the BSP source reorganization. Update #3285. | |||||
2018-04-20 | bsp-howto: Update BSP source code structure | Sebastian Huber | 1 | -91/+41 | |
2017-11-20 | Clarify INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAIL | Sebastian Huber | 1 | -1/+4 | |
Update #3239. | |||||
2017-11-17 | bsp-howto: Add getentropy. | Christian Mauderer | 2 | -0/+40 | |
2017-11-16 | bsp-howto/console: Move misplaced var. in example | Martin Erik Werner | 1 | -1/+1 | |
Signed-off-by: Martin Erik Werner <martinerikwerner@gmail.com> | |||||
2017-11-12 | Add indexes to all documents. | Chris Johns | 2 | -2/+5 | |
Update #3229. | |||||
2017-10-12 | Shorten BSP and Driver Guide name (missed commit) | Joel Sherrill | 1 | -1/+1 | |
Updates #3141. | |||||
2017-10-12 | Shorten the name of the BSP and Device Driver Development Guide | Joel Sherrill | 2 | -4/+4 | |
Old name: RTEMS BSP and Device Driver Development Guide This is long and causes problems in the PDF output. This patch changes the name to: RTEMS BSP and Driver Guide Closes #3141. | |||||
2017-09-18 | bsp-howto: Clock_driver_support_install_isr() | Sebastian Huber | 1 | -3/+5 | |
Close #3139. | |||||
2017-08-11 | Update copyright notices. | Chris Johns | 1 | -6/+9 | |
2017-08-04 | bsp: Optional clock driver shutdown | Sebastian Huber | 1 | -4/+8 | |
2017-06-08 | bsp-howto: Warn about TERMIOS_TASK_DRIVEN | Sebastian Huber | 1 | -0/+2 | |
Update #2935. | |||||
2017-03-27 | waf: Cleaner formatting to see the importing. | Chris Johns | 1 | -2/+7 | |
2017-03-20 | Use a single top level version number. | Chris Johns | 1 | -4/+5 | |
2017-01-11 | Update document titles for consistency | Joel Sherrill | 1 | -5/+5 | |
2016-12-23 | Update Console Driver chapter | Sebastian Huber | 1 | -382/+346 | |
Close #2785. Close #2838. | |||||
2016-12-21 | Strip down BSP Introduction | Sebastian Huber | 1 | -49/+13 | |
Update #2852. | |||||
2016-12-21 | Add warnings to basic BSP chapters | Sebastian Huber | 5 | -0/+20 | |
2016-12-21 | Move Shared Memory Support Driver chapter | Sebastian Huber | 1 | -1/+1 | |
This chapter is very specific. Move it to a less prominent chapter position. | |||||
2016-12-21 | Move Ada95 Interrupt Support chapter | Sebastian Huber | 1 | -1/+1 | |
2016-12-21 | Add warning to Timer Driver chapter | Sebastian Huber | 2 | -1/+6 | |
Move Timer Driver chapter. Update #2847. | |||||
2016-12-21 | Add warning to ATA/IDE driver chapter | Sebastian Huber | 3 | -2/+16 | |
Close #2849. | |||||
2016-12-21 | Remove Non-Volatile Memory Driver chapter | Sebastian Huber | 2 | -218/+0 | |
There exists no standard Non-Volatile Memory Driver in the RTEMS code base. Close #2851. | |||||
2016-12-21 | Remove Discrete Driver chapter | Sebastian Huber | 2 | -191/+0 | |
There exists no standard Discrete Driver in the RTEMS code base. Close #2851. | |||||
2016-12-21 | Remove Analog Driver chapter | Sebastian Huber | 2 | -166/+0 | |
There exists no standard Analog Driver in the RTEMS code base. Close #2850. | |||||
2016-12-21 | Document I2C framework | Sebastian Huber | 2 | -0/+20 | |
Update #2845. | |||||
2016-12-21 | Document SPI framework | Sebastian Huber | 2 | -0/+20 | |
Update #2776. | |||||
2016-12-21 | Update version/revision to 4.11.99 | Sebastian Huber | 1 | -2/+2 | |
2016-12-21 | Rework Clock Driver chapter | Sebastian Huber | 1 | -100/+137 | |
Update #2737. | |||||
2016-11-09 | bsp-howto: Increase the number depth of sections. | Chris Johns | 1 | -1/+1 | |
2016-11-09 | bsp-howto: Fix header levels. | Chris Johns | 20 | -23/+22 | |
2016-11-03 | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 23 | -0/+4656 | |
