path: root/bsp-howto/target_dependant_files.rst (follow)
* Simplify SPDX-License-Identifier commentSebastian Huber2019-01-111-1/+1
* Remove superfluous "All rights reserved."Sebastian Huber2019-01-111-1/+0
* Use standard format for copyright linesSebastian Huber2019-01-111-2/+1
* Update due to BSP source reorganizationSebastian Huber2018-04-271-13/+12
| | | | | | This patch is a part of the BSP source reorganization. Close #3285.
* bsp-howto: Avoid :file: role with ${...}Sebastian Huber2018-04-231-4/+4
| | | | | | | | The curly braces have a special meaning in the :file: role. This patch is a part of the BSP source reorganization. Update #3285.
* bsp-howto: Update BSP source code structureSebastian Huber2018-04-201-91/+41
* Add warnings to basic BSP chaptersSebastian Huber2016-12-211-0/+4
| | | | Update #2852.
* bsp-howto: Fix header levels.Chris Johns2016-11-091-1/+1
* Rename all manuals with an _ to have a -. It helps released naming of files.Chris Johns2016-11-031-0/+229
