path: root/bsp-howto/miscellanous_support.rst (unfollow)
2022-11-08Update build system related sections for RTEMS 6Sebastian Huber1-38/+0
Update sections which contained the word "bsp_specs".
2020-02-06Remove BSP_ZERO_WORKSPACE_AUTOMATICALLYSebastian Huber1-7/+0
Close #3863.
2019-11-22bsp-howto/miscellanous_support.rst: Fix grammar mistake.Joel Sherrill1-1/+1
2019-09-03Address several issues from compiling examplesMartin Erik Werner1-1/+1
Compiling the code from examples "code-block:: c" along with public includes and a bsp exposed a few issues amongst a lot of false positives. Address some of these: * Terminate struct declarations with ';'. Mainly for pedantic correctness. * Show ptrdiff_t instead of size_t for the sbrk() prototype, matching the current argument type in rtems. * Replace some occurrences of unsigned16 with uint16_t. * Fix odd type declaration, "uint8_t char*" -> "char*". * Use appropriate helper to get chain head instead of invalid access to nonexistent struct member. * Remove several excess '\' escapes. * Use RTEMS_SELF instead of undefined SELF. * Use rtems_task instead of void for task functions. * Add missing stack size parameter in task creation. * Use rtems_interrupt_level instead of undefined rtems_interrupt. * Correct return value format for rtems_object_id_get_api() rtems_object_id_get_index() (enum and uint16_t) and also fix corresponding print formatting. * Correct return value documentation for rtems_object_id_get_class(), rtems_object_id_get_node() and rtems_object_id_get_index() int -> uint32_t. * Use RTEMS_SUCCESSFUL instead of undefined RTEMS_STATUS_SUCCESSFUL and fix return value variable name in rate monotonic examples. * Use RTEMS_TIMEOUT instead of undefined TIMEOUT and RTEMS_PERIOD_STATUS instead of undefined STATUS. * Add missing fields to ftpd configuration. * Correct parameter types in ftpd hook prototype, unsigned char * -> void *. * Fix various code-block:: attributes, c -> makefile and c -> shell. * Add missing parenthesis in socket buffer memory calculation example. * Remove typedef in declaration of mq_attr since it is defiend without typedef in reality. * Update siginfo_t declaration to match current reality. * Update shell user command definition example to include mode, uid and gid.
2019-01-11Simplify SPDX-License-Identifier commentSebastian Huber1-1/+1
2019-01-11Remove superfluous "All rights reserved."Sebastian Huber1-1/+0
2019-01-11Use standard format for copyright linesSebastian Huber1-2/+1
2018-04-27Update due to BSP source reorganizationSebastian Huber1-30/+7
This patch is a part of the BSP source reorganization. Close #3285.
2016-12-21Add warnings to basic BSP chaptersSebastian Huber1-0/+4
Update #2852.
2016-11-09bsp-howto: Fix header levels.Chris Johns1-2/+2
2016-11-03Rename all manuals with an _ to have a -. It helps released naming of files.Chris Johns1-0/+0
2016-10-27bsp_howto: Fix code-block markupJoel Sherrill1-5/+5
2016-10-27rtems-docs: Fix many unnecessary back slashesJoel Sherrill1-4/+4
2016-06-17Update the BSP howto.Chris Johns1-207/+219
Closes #2590.
2016-05-20Set SPDX License Identifier in each source file.Chris Johns1-0/+2
2016-05-02Convert all Unicode to ASCII(128)Amar Takhar1-1/+1
2016-05-02Split document into seperate files by section.Amar Takhar1-0/+350
