2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2021-04-22 | bsp-howto: Add target hash chapter | Sebastian Huber | 1 | -0/+1 | |
Update #4267. | |||||
2020-02-04 | bsp-howto: Rework system initialization chapter | Sebastian Huber | 1 | -2/+2 | |
Update #2852. Update #3838. | |||||
2019-04-04 | bsp-howto: Move BSP Doxygen recommendations | Sebastian Huber | 1 | -0/+1 | |
Update #3704. | |||||
2019-02-28 | Add unicode support for commonly used characters like copyright. | Chris Johns | 1 | -4/+6 | |
- This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals. | |||||
2019-02-15 | Use pathto() on the genindex URL to make it relative. | Chris Johns | 1 | -2/+0 | |
2019-01-14 | Reformat and update copyright and license notices | Sebastian Huber | 1 | -8/+8 | |
For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | |||||
2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 1 | -1/+1 | |
2019-01-09 | Add common header.rst to reduce copy and paste | Sebastian Huber | 1 | -23/+1 | |
2018-10-19 | Update the copyright year. | Chris Johns | 1 | -1/+1 | |
2018-08-21 | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 1 | -1/+1 | |
- Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | |||||
2018-04-27 | Update due to BSP source reorganization | Sebastian Huber | 1 | -1/+0 | |
This patch is a part of the BSP source reorganization. Close #3285. | |||||
2017-11-17 | bsp-howto: Add getentropy. | Christian Mauderer | 1 | -0/+1 | |
Update #3239. | |||||
2017-11-12 | Add indexes to all documents. | Chris Johns | 1 | -2/+1 | |
Update #3229. | |||||
2017-10-12 | Shorten the name of the BSP and Device Driver Development Guide | Joel Sherrill | 1 | -3/+3 | |
Old name: RTEMS BSP and Device Driver Development Guide This is long and causes problems in the PDF output. This patch changes the name to: RTEMS BSP and Driver Guide Closes #3141. | |||||
2017-08-11 | Update copyright notices. | Chris Johns | 1 | -6/+9 | |
2017-01-11 | Update document titles for consistency | Joel Sherrill | 1 | -5/+5 | |
2016-12-21 | Move Shared Memory Support Driver chapter | Sebastian Huber | 1 | -1/+1 | |
This chapter is very specific. Move it to a less prominent chapter position. | |||||
2016-12-21 | Move Ada95 Interrupt Support chapter | Sebastian Huber | 1 | -1/+1 | |
2016-12-21 | Add warning to Timer Driver chapter | Sebastian Huber | 1 | -1/+1 | |
Move Timer Driver chapter. Update #2847. | |||||
2016-12-21 | Add warning to ATA/IDE driver chapter | Sebastian Huber | 1 | -2/+2 | |
Close #2849. | |||||
2016-12-21 | Remove Non-Volatile Memory Driver chapter | Sebastian Huber | 1 | -1/+0 | |
There exists no standard Non-Volatile Memory Driver in the RTEMS code base. Close #2851. | |||||
2016-12-21 | Remove Discrete Driver chapter | Sebastian Huber | 1 | -1/+0 | |
There exists no standard Discrete Driver in the RTEMS code base. Close #2851. | |||||
2016-12-21 | Remove Analog Driver chapter | Sebastian Huber | 1 | -1/+0 | |
There exists no standard Analog Driver in the RTEMS code base. Close #2850. | |||||
2016-12-21 | Document I2C framework | Sebastian Huber | 1 | -0/+1 | |
Update #2845. | |||||
2016-12-21 | Document SPI framework | Sebastian Huber | 1 | -0/+1 | |
Update #2776. | |||||
2016-11-09 | bsp-howto: Increase the number depth of sections. | Chris Johns | 1 | -1/+1 | |
2016-11-03 | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 1 | -0/+0 | |
2016-06-17 | Update the BSP howto. | Chris Johns | 1 | -33/+30 | |
Closes #2590. | |||||
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 1 | -0/+2 | |
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 1 | -1/+1 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -1/+64 | |
