* | Update copyright notices. | Chris Johns | 2017-08-11 | 1 | -6/+9 |
* | Update document titles for consistency | Joel Sherrill | 2017-01-11 | 1 | -5/+5 |
* | Move Shared Memory Support Driver chapter | Sebastian Huber | 2016-12-21 | 1 | -1/+1 |
| | | | | | This chapter is very specific. Move it to a less prominent chapter position. | ||||
* | Move Ada95 Interrupt Support chapter | Sebastian Huber | 2016-12-21 | 1 | -1/+1 |
* | Add warning to Timer Driver chapter | Sebastian Huber | 2016-12-21 | 1 | -1/+1 |
| | | | | | | Move Timer Driver chapter. Update #2847. | ||||
* | Add warning to ATA/IDE driver chapter | Sebastian Huber | 2016-12-21 | 1 | -2/+2 |
| | | | | Close #2849. | ||||
* | Remove Non-Volatile Memory Driver chapter | Sebastian Huber | 2016-12-21 | 1 | -1/+0 |
| | | | | | | | There exists no standard Non-Volatile Memory Driver in the RTEMS code base. Close #2851. | ||||
* | Remove Discrete Driver chapter | Sebastian Huber | 2016-12-21 | 1 | -1/+0 |
| | | | | | | There exists no standard Discrete Driver in the RTEMS code base. Close #2851. | ||||
* | Remove Analog Driver chapter | Sebastian Huber | 2016-12-21 | 1 | -1/+0 |
| | | | | | | There exists no standard Analog Driver in the RTEMS code base. Close #2850. | ||||
* | Document I2C framework | Sebastian Huber | 2016-12-21 | 1 | -0/+1 |
| | | | | Update #2845. | ||||
* | Document SPI framework | Sebastian Huber | 2016-12-21 | 1 | -0/+1 |
| | | | | Update #2776. | ||||
* | bsp-howto: Increase the number depth of sections. | Chris Johns | 2016-11-09 | 1 | -1/+1 |
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 1 | -0/+63 |
