path: root/bsp-howto/index.rst (follow)
* bsp-howto: Add target hash chapterSebastian Huber2021-04-221-0/+1
| | | | Update #4267.
* bsp-howto: Rework system initialization chapterSebastian Huber2020-02-041-2/+2
| | | | | Update #2852. Update #3838.
* bsp-howto: Move BSP Doxygen recommendationsSebastian Huber2019-04-041-0/+1
| | | | Update #3704.
* Add unicode support for commonly used characters like copyright.Chris Johns2019-02-281-4/+6
| | | | | - This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals.
* Use pathto() on the genindex URL to make it relative.Chris Johns2019-02-151-2/+0
* Reformat and update copyright and license noticesSebastian Huber2019-01-141-8/+8
| | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete.
* Simplify SPDX-License-Identifier commentSebastian Huber2019-01-111-1/+1
* Add common header.rst to reduce copy and pasteSebastian Huber2019-01-091-23/+1
* Update the copyright year.Chris Johns2018-10-191-1/+1
* build: Fix indexing so it works on HTML and PDF.Chris Johns2018-08-211-1/+1
| | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503
* Update due to BSP source reorganizationSebastian Huber2018-04-271-1/+0
| | | | | | This patch is a part of the BSP source reorganization. Close #3285.
* bsp-howto: Add getentropy.Christian Mauderer2017-11-171-0/+1
| | | | Update #3239.
* Add indexes to all documents.Chris Johns2017-11-121-2/+1
| | | | Update #3229.
* Shorten the name of the BSP and Device Driver Development GuideJoel Sherrill2017-10-121-3/+3
| | | | | | | | | | | | | Old name: RTEMS BSP and Device Driver Development Guide This is long and causes problems in the PDF output. This patch changes the name to: RTEMS BSP and Driver Guide Closes #3141.
* Update copyright notices.Chris Johns2017-08-111-6/+9
* Update document titles for consistencyJoel Sherrill2017-01-111-5/+5
* Move Shared Memory Support Driver chapterSebastian Huber2016-12-211-1/+1
| | | | | This chapter is very specific. Move it to a less prominent chapter position.
* Move Ada95 Interrupt Support chapterSebastian Huber2016-12-211-1/+1
* Add warning to Timer Driver chapterSebastian Huber2016-12-211-1/+1
| | | | | | Move Timer Driver chapter. Update #2847.
* Add warning to ATA/IDE driver chapterSebastian Huber2016-12-211-2/+2
| | | | Close #2849.
* Remove Non-Volatile Memory Driver chapterSebastian Huber2016-12-211-1/+0
| | | | | | | There exists no standard Non-Volatile Memory Driver in the RTEMS code base. Close #2851.
* Remove Discrete Driver chapterSebastian Huber2016-12-211-1/+0
| | | | | | There exists no standard Discrete Driver in the RTEMS code base. Close #2851.
* Remove Analog Driver chapterSebastian Huber2016-12-211-1/+0
| | | | | | There exists no standard Analog Driver in the RTEMS code base. Close #2850.
* Document I2C frameworkSebastian Huber2016-12-211-0/+1
| | | | Update #2845.
* Document SPI frameworkSebastian Huber2016-12-211-0/+1
| | | | Update #2776.
* bsp-howto: Increase the number depth of sections.Chris Johns2016-11-091-1/+1
* Rename all manuals with an _ to have a -. It helps released naming of files.Chris Johns2016-11-031-0/+63
