* | bsp-howto: Rework system initialization chapter | Sebastian Huber | 2020-02-04 | 1 | -2/+2 |
| | | | | | Update #2852. Update #3838. | ||||
* | bsp-howto: Move BSP Doxygen recommendations | Sebastian Huber | 2019-04-04 | 1 | -0/+1 |
| | | | | Update #3704. | ||||
* | Add unicode support for commonly used characters like copyright. | Chris Johns | 2019-02-28 | 1 | -4/+6 |
| | | | | | - This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals. | ||||
* | Use pathto() on the genindex URL to make it relative. | Chris Johns | 2019-02-15 | 1 | -2/+0 |
* | Reformat and update copyright and license notices | Sebastian Huber | 2019-01-14 | 1 | -8/+8 |
| | | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 1 | -23/+1 |
* | Update the copyright year. | Chris Johns | 2018-10-19 | 1 | -1/+1 |
* | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2018-08-21 | 1 | -1/+1 |
| | | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | ||||
* | Update due to BSP source reorganization | Sebastian Huber | 2018-04-27 | 1 | -1/+0 |
| | | | | | | This patch is a part of the BSP source reorganization. Close #3285. | ||||
* | bsp-howto: Add getentropy. | Christian Mauderer | 2017-11-17 | 1 | -0/+1 |
| | | | | Update #3239. | ||||
* | Add indexes to all documents. | Chris Johns | 2017-11-12 | 1 | -2/+1 |
| | | | | Update #3229. | ||||
* | Shorten the name of the BSP and Device Driver Development Guide | Joel Sherrill | 2017-10-12 | 1 | -3/+3 |
| | | | | | | | | | | | | | Old name: RTEMS BSP and Device Driver Development Guide This is long and causes problems in the PDF output. This patch changes the name to: RTEMS BSP and Driver Guide Closes #3141. | ||||
* | Update copyright notices. | Chris Johns | 2017-08-11 | 1 | -6/+9 |
* | Update document titles for consistency | Joel Sherrill | 2017-01-11 | 1 | -5/+5 |
* | Move Shared Memory Support Driver chapter | Sebastian Huber | 2016-12-21 | 1 | -1/+1 |
| | | | | | This chapter is very specific. Move it to a less prominent chapter position. | ||||
* | Move Ada95 Interrupt Support chapter | Sebastian Huber | 2016-12-21 | 1 | -1/+1 |
* | Add warning to Timer Driver chapter | Sebastian Huber | 2016-12-21 | 1 | -1/+1 |
| | | | | | | Move Timer Driver chapter. Update #2847. | ||||
* | Add warning to ATA/IDE driver chapter | Sebastian Huber | 2016-12-21 | 1 | -2/+2 |
| | | | | Close #2849. | ||||
* | Remove Non-Volatile Memory Driver chapter | Sebastian Huber | 2016-12-21 | 1 | -1/+0 |
| | | | | | | | There exists no standard Non-Volatile Memory Driver in the RTEMS code base. Close #2851. | ||||
* | Remove Discrete Driver chapter | Sebastian Huber | 2016-12-21 | 1 | -1/+0 |
| | | | | | | There exists no standard Discrete Driver in the RTEMS code base. Close #2851. | ||||
* | Remove Analog Driver chapter | Sebastian Huber | 2016-12-21 | 1 | -1/+0 |
| | | | | | | There exists no standard Analog Driver in the RTEMS code base. Close #2850. | ||||
* | Document I2C framework | Sebastian Huber | 2016-12-21 | 1 | -0/+1 |
| | | | | Update #2845. | ||||
* | Document SPI framework | Sebastian Huber | 2016-12-21 | 1 | -0/+1 |
| | | | | Update #2776. | ||||
* | bsp-howto: Increase the number depth of sections. | Chris Johns | 2016-11-09 | 1 | -1/+1 |
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 1 | -0/+63 |
