2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 1 | -1/+1 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 1 | -1/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 1 | -2/+1 | |
2018-04-27 | Update due to BSP source reorganization | Sebastian Huber | 1 | -5/+4 | |
This patch is a part of the BSP source reorganization. Close #3285. | |||||
2016-12-21 | Add warning to ATA/IDE driver chapter | Sebastian Huber | 1 | -0/+7 | |
Close #2849. | |||||
2016-11-09 | bsp-howto: Fix header levels. | Chris Johns | 1 | -1/+1 | |
2016-11-03 | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 1 | -0/+0 | |
2016-06-17 | Update the BSP howto. | Chris Johns | 1 | -73/+87 | |
Closes #2590. | |||||
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 1 | -0/+2 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -0/+140 | |
