2019-02-08 | build: Prepend project common path | Sebastian Huber | 1 | -1/+1 | |
This avoids conflicts with standard packages such as PIL (Python Imaging Library). | |||||
2017-10-12 | Shorten BSP and Driver Guide name (missed commit) | Joel Sherrill | 1 | -1/+1 | |
Updates #3141. | |||||
2017-10-12 | Shorten the name of the BSP and Device Driver Development Guide | Joel Sherrill | 1 | -1/+1 | |
Old name: RTEMS BSP and Device Driver Development Guide This is long and causes problems in the PDF output. This patch changes the name to: RTEMS BSP and Driver Guide Closes #3141. | |||||
2017-03-20 | Use a single top level version number. | Chris Johns | 1 | -4/+5 | |
2016-12-21 | Update version/revision to 4.11.99 | Sebastian Huber | 1 | -2/+2 | |
2016-11-03 | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 1 | -1/+1 | |
2016-06-17 | Update the BSP howto. | Chris Johns | 1 | -4/+5 | |
Closes #2590. | |||||
2016-05-02 | Add PDF generation support use with --pdf | Amar Takhar | 1 | -0/+4 | |
2016-05-02 | Rework how conf.py is handled. | Amar Takhar | 1 | -0/+8 | |
Needed to switch due to increasing complexity. |
