* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 1 | -1/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 1 | -2/+1 |
* | bsp-howto: Mention clock driver hook removal | Sebastian Huber | 2018-06-26 | 1 | -22/+1 |
| | | | | Update #3436. | ||||
* | Update due to BSP source reorganization | Sebastian Huber | 2018-04-27 | 1 | -12/+12 |
| | | | | | | This patch is a part of the BSP source reorganization. Close #3285. | ||||
* | bsp-howto: Clock_driver_support_install_isr() | Sebastian Huber | 2017-09-18 | 1 | -3/+5 |
| | | | | Close #3139. | ||||
* | bsp: Optional clock driver shutdown | Sebastian Huber | 2017-08-04 | 1 | -4/+8 |
* | Rework Clock Driver chapter | Sebastian Huber | 2016-12-21 | 1 | -100/+137 |
| | | | | Update #2737. | ||||
* | bsp-howto: Fix header levels. | Chris Johns | 2016-11-09 | 1 | -1/+1 |
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 1 | -0/+297 |
