* | Add PDF generation support use with --pdf | Amar Takhar | 2016-05-02 | 1 | -0/+4 |
* | Add support for spellchecking with a custom dictionary. | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
| | | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | ||||
* | Rework how conf.py is handled. | Amar Takhar | 2016-05-02 | 2 | -9/+12 |
| | | | | Needed to switch due to increasing complexity. | ||||
* | Fix rtemsconfig building. | Amar Takhar | 2016-05-02 | 2 | -8/+15 |
| | | | | | I'll probably move to a more pythonic way of doing conf.py since this is getting too complicated. | ||||
* | Check for non existent directories when building 'book'. | Amar Takhar | 2016-05-02 | 1 | -2/+6 |
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 2 | -0/+88 |
