2024-02-21 | sphinx: Use the pip installed sphinx-rtd-theme | Chris Johns | 1 | -2/+29 | |
- Remove the RTEMS version of the theme - Use conf.py to specify our style sheet - Depend on the jQuery contrib package for including jQuery - Detect the theme is installed Closes #4994 | |||||
2023-08-09 | Add Regulator documentation based on V1 functionality | Joel Sherrill | 1 | -2/+17 | |
2023-06-16 | README: Fixing spelling and grammar errors | Stanley V. Paulauskas | 1 | -15/+15 | |
Most of the mistakes were in the body text, which hindered only clarity. One mistake was found in the Document Standard item 7, which would prevent the provided code snippit from working. | |||||
2022-10-13 | README: Add a note about image tools | Chris Johns | 1 | -0/+15 | |
2022-08-03 | building: Add support for an RTEMS version number | Chris Johns | 1 | -0/+31 | |
- Support using a version number for RTEMS documentation Updates #4695 | |||||
2021-07-20 | README: Added centOS 8 instructions | Stephen Clark | 1 | -0/+11 | |
Added some instructions for setting up CentOS 8. | |||||
2021-07-20 | README: Minor clarifications and fixes | Stephen Clark | 1 | -24/+25 | |
Fixed some minor typographical errors. Updated a dead link. Reworded some sentences for clarity. | |||||
2020-08-12 | user, README: Add Python script host set up information | Chris Johns | 1 | -6/+12 | |
- Add Python3 and venv to the README - Add a section on how to set up a host if the python command is not available. Update #4037 | |||||
2020-04-03 | RTEMS Docs: Add steps for sphinxcontrib-bibtex | Vaibhav Gupta | 1 | -0/+1 | |
Add step to install sphinxcontrib-bibtex together with the steps mentioned for ArcLinux, to install sphinx and dependencies. Signed-off-by: Vaibhav Gupta <vaibhavgupta40@gmail.com> | |||||
2020-04-03 | Add virtualenv to the README.txt as the preferred host support. | Chris Johns | 1 | -1/+21 | |
2019-11-06 | README.txt: Add info on CentOS 7 Software Collections for Python 3 | Joel Sherrill | 1 | -2/+24 | |
2019-08-15 | Remove back-slash in 'pacman' command in 'PDF' section under Arch Linux ↵ | Vaibhav Gupta | 1 | -1/+1 | |
(installation of Sphinx). | |||||
2019-02-28 | Add commands and output to the README. | Chris Johns | 1 | -4/+24 | |
2019-02-28 | Add a cheetsheet link to the README.txt | Chris Johns | 1 | -0/+4 | |
2019-02-28 | waf: Change --sphinx-verbose to --sphinx-options, add --sphinx-nit-pick | Chris Johns | 1 | -4/+40 | |
Provide options to manage sphinx. Make using the nit-picky mode simpler to access. | |||||
2019-02-13 | README.txt: Fix typos | Joel Sherrill | 1 | -2/+2 | |
2018-11-16 | README.txt: Fix grammar errors (GCI 2018) | Aneendya | 1 | -3/+3 | |
2018-11-03 | user: Add RTEMS executable and test documentation. | Chris Johns | 1 | -2/+41 | |
2018-11-03 | waf: Add support to build PlantUML and Ditaa images. | Chris Johns | 1 | -1/+16 | |
2017-07-26 | README: fix typos | Gedare Bloom | 1 | -8/+8 | |
2017-05-31 | Fixes typos in README.txt | Tanu Hari Dixit | 1 | -2/+2 | |
2 typos fixed | |||||
2017-04-25 | README.txt: Add info after installing on CentOS 7 | Joel Sherrill | 1 | -5/+22 | |
2017-03-27 | Add Windows build details. | Chris Johns | 1 | -0/+23 | |
Actually include the quoting fix for Windows. | |||||
2017-02-20 | Render math via JavaScript in HTML output | Sebastian Huber | 1 | -3/+2 | |
2017-02-02 | Update README due to use of math extension | Sebastian Huber | 1 | -2/+3 | |
2017-01-20 | Mention sphinxcontrib-bibtex in README | Sebastian Huber | 1 | -1/+3 | |
2016-11-09 | waf: Users without the extra fonts need to use '--disable-extra-fonts' to ↵ | Chris Johns | 1 | -2/+7 | |
build PDF. | |||||
2016-11-09 | README: Add coding of spaces and no trailing white space. | Chris Johns | 1 | -7/+9 | |
2016-11-09 | README: Fix the header levels. | Chris Johns | 1 | -6/+8 | |
2016-11-08 | README.txt: Add notes on Centos 6 and 7 | Joel Sherrill | 1 | -5/+46 | |
2016-11-07 | Add openSUSE installation hints | Sebastian Huber | 1 | -1/+14 | |
2016-11-07 | README: Add packages for building on Arch. | Christian Mauderer | 1 | -0/+12 | |
2016-11-06 | README: Update with more host specific details. | Chris Johns | 1 | -18/+40 | |
2016-11-04 | waf: note about tex noise when running configure. | Chris Johns | 1 | -0/+3 | |
2016-11-04 | README: Add host set up for CentOS for singlehtml. | Chris Johns | 1 | -0/+5 | |
2016-11-04 | waf: Check for texlive packages and report an error is not found. | Chris Johns | 1 | -3/+92 | |
2016-11-03 | README: Add host set up and update the build commands. | Chris Johns | 1 | -5/+38 | |
2016-11-02 | Update the top level README.txt. | Chris Johns | 1 | -9/+19 | |
2016-11-01 | Add some notes on writing documentation. | Chris Johns | 1 | -0/+130 | |
