path: root/README.txt (follow)
* RTEMS Docs: Add steps for sphinxcontrib-bibtexVaibhav Gupta2020-04-031-0/+1
| | | | | | | | Add step to install sphinxcontrib-bibtex together with the steps mentioned for ArcLinux, to install sphinx and dependencies. Signed-off-by: Vaibhav Gupta <vaibhavgupta40@gmail.com>
* Add virtualenv to the README.txt as the preferred host support.Chris Johns2020-04-031-1/+21
* README.txt: Add info on CentOS 7 Software Collections for Python 3Joel Sherrill2019-11-061-2/+24
* Remove back-slash in 'pacman' command in 'PDF' section under Arch Linux ↵Vaibhav Gupta2019-08-151-1/+1
| | | | (installation of Sphinx).
* Add commands and output to the README.Chris Johns2019-02-281-4/+24
* Add a cheetsheet link to the README.txtChris Johns2019-02-281-0/+4
* waf: Change --sphinx-verbose to --sphinx-options, add --sphinx-nit-pickChris Johns2019-02-281-4/+40
| | | | | Provide options to manage sphinx. Make using the nit-picky mode simpler to access.
* README.txt: Fix typosJoel Sherrill2019-02-131-2/+2
* README.txt: Fix grammar errors (GCI 2018)Aneendya2018-11-161-3/+3
* user: Add RTEMS executable and test documentation.Chris Johns2018-11-031-2/+41
* waf: Add support to build PlantUML and Ditaa images.Chris Johns2018-11-031-1/+16
* README: fix typosGedare Bloom2017-07-261-8/+8
* Fixes typos in README.txtTanu Hari Dixit2017-05-311-2/+2
| | | | 2 typos fixed
* README.txt: Add info after installing on CentOS 7Joel Sherrill2017-04-251-5/+22
* Add Windows build details.Chris Johns2017-03-271-0/+23
| | | | Actually include the quoting fix for Windows.
* Render math via JavaScript in HTML outputSebastian Huber2017-02-201-3/+2
* Update README due to use of math extensionSebastian Huber2017-02-021-2/+3
* Mention sphinxcontrib-bibtex in READMESebastian Huber2017-01-201-1/+3
* waf: Users without the extra fonts need to use '--disable-extra-fonts' to ↵Chris Johns2016-11-091-2/+7
| | | | build PDF.
* README: Add coding of spaces and no trailing white space.Chris Johns2016-11-091-7/+9
* README: Fix the header levels.Chris Johns2016-11-091-6/+8
* README.txt: Add notes on Centos 6 and 7Joel Sherrill2016-11-081-5/+46
* Add openSUSE installation hintsSebastian Huber2016-11-071-1/+14
* README: Add packages for building on Arch.Christian Mauderer2016-11-071-0/+12
* README: Update with more host specific details.Chris Johns2016-11-061-18/+40
* waf: note about tex noise when running configure.Chris Johns2016-11-041-0/+3
* README: Add host set up for CentOS for singlehtml.Chris Johns2016-11-041-0/+5
* waf: Check for texlive packages and report an error is not found.Chris Johns2016-11-041-3/+92
* README: Add host set up and update the build commands.Chris Johns2016-11-031-5/+38
* Update the top level README.txt.Chris Johns2016-11-021-9/+19
* Add some notes on writing documentation.Chris Johns2016-11-011-0/+130
