path: root/README.txt (unfollow)
2017-07-26README: fix typosGedare Bloom1-8/+8
2017-05-31Fixes typos in README.txtTanu Hari Dixit1-2/+2
2 typos fixed
2017-04-25README.txt: Add info after installing on CentOS 7Joel Sherrill1-5/+22
2017-03-27Add Windows build details.Chris Johns1-0/+23
Actually include the quoting fix for Windows.
2017-02-20Render math via JavaScript in HTML outputSebastian Huber1-3/+2
2017-02-02Update README due to use of math extensionSebastian Huber1-2/+3
2017-01-20Mention sphinxcontrib-bibtex in READMESebastian Huber1-1/+3
2016-11-09waf: Users without the extra fonts need to use '--disable-extra-fonts' to ↵Chris Johns1-2/+7
build PDF.
2016-11-09README: Add coding of spaces and no trailing white space.Chris Johns1-7/+9
2016-11-09README: Fix the header levels.Chris Johns1-6/+8
2016-11-08README.txt: Add notes on Centos 6 and 7Joel Sherrill1-5/+46
2016-11-07Add openSUSE installation hintsSebastian Huber1-1/+14
2016-11-07README: Add packages for building on Arch.Christian Mauderer1-0/+12
2016-11-06README: Update with more host specific details.Chris Johns1-18/+40
2016-11-04waf: note about tex noise when running configure.Chris Johns1-0/+3
2016-11-04README: Add host set up for CentOS for singlehtml.Chris Johns1-0/+5
2016-11-04waf: Check for texlive packages and report an error is not found.Chris Johns1-3/+92
2016-11-03README: Add host set up and update the build commands.Chris Johns1-5/+38
2016-11-02Update the top level README.txt.Chris Johns1-9/+19
2016-11-01Add some notes on writing documentation.Chris Johns1-0/+130
