path: root/README.txt (follow)
* README: Add coding of spaces and no trailing white space.Chris Johns2016-11-091-7/+9
* README: Fix the header levels.Chris Johns2016-11-091-6/+8
* README.txt: Add notes on Centos 6 and 7Joel Sherrill2016-11-081-5/+46
* Add openSUSE installation hintsSebastian Huber2016-11-071-1/+14
* README: Add packages for building on Arch.Christian Mauderer2016-11-071-0/+12
* README: Update with more host specific details.Chris Johns2016-11-061-18/+40
* waf: note about tex noise when running configure.Chris Johns2016-11-041-0/+3
* README: Add host set up for CentOS for singlehtml.Chris Johns2016-11-041-0/+5
* waf: Check for texlive packages and report an error is not found.Chris Johns2016-11-041-3/+92
* README: Add host set up and update the build commands.Chris Johns2016-11-031-5/+38
* Update the top level README.txt.Chris Johns2016-11-021-9/+19
* Add some notes on writing documentation.Chris Johns2016-11-011-0/+130
