index
rtems-docs
4.11
5
master
RTEMS Project documentation.
devel@rtems.org
summary
refs
log
tree
commit
diff
stats
log msg
author
committer
range
path:
root
README.txt
follow
Commit message (
Collapse
Author
Age
Lines
user: Add RTEMS executable and test documentation.
Chris Johns
2018-11-03
1
-2
+41
waf: Add support to build PlantUML and Ditaa images.
Chris Johns
2018-11-03
1
-1
+16
README: fix typos
Gedare Bloom
2017-07-26
1
-8
+8
Fixes typos in README.txt
Tanu Hari Dixit
2017-05-31
1
-2
+2
2 typos fixed
README.txt: Add info after installing on CentOS 7
Joel Sherrill
2017-04-25
1
-5
+22
Add Windows build details.
Chris Johns
2017-03-27
1
-0
+23
Actually include the quoting fix for Windows.
Render math via JavaScript in HTML output
Sebastian Huber
2017-02-20
1
-3
+2
Update README due to use of math extension
Sebastian Huber
2017-02-02
1
-2
+3
Mention sphinxcontrib-bibtex in README
Sebastian Huber
2017-01-20
1
-1
+3
waf: Users without the extra fonts need to use '--disable-extra-fonts' to ↵
Chris Johns
2016-11-09
1
-2
+7
build PDF.
README: Add coding of spaces and no trailing white space.
Chris Johns
2016-11-09
1
-7
+9
README: Fix the header levels.
Chris Johns
2016-11-09
1
-6
+8
README.txt: Add notes on Centos 6 and 7
Joel Sherrill
2016-11-08
1
-5
+46
Add openSUSE installation hints
Sebastian Huber
2016-11-07
1
-1
+14
README: Add packages for building on Arch.
Christian Mauderer
2016-11-07
1
-0
+12
README: Update with more host specific details.
Chris Johns
2016-11-06
1
-18
+40
waf: note about tex noise when running configure.
Chris Johns
2016-11-04
1
-0
+3
README: Add host set up for CentOS for singlehtml.
Chris Johns
2016-11-04
1
-0
+5
waf: Check for texlive packages and report an error is not found.
Chris Johns
2016-11-04
1
-3
+92
README: Add host set up and update the build commands.
Chris Johns
2016-11-03
1
-5
+38
Update the top level README.txt.
Chris Johns
2016-11-02
1
-9
+19
Add some notes on writing documentation.
Chris Johns
2016-11-01
1
-0
+130
