index
rtems-docs
4.11
5
master
RTEMS Project documentation.
devel@rtems.org
summary
refs
log
tree
commit
diff
stats
log msg
author
committer
range
path:
root
README.txt
unfollow
Commit message (
Collapse
Author
Lines
2019-11-06
README.txt: Add info on CentOS 7 Software Collections for Python 3
Joel Sherrill
1
-2
+24
2019-08-15
Remove back-slash in 'pacman' command in 'PDF' section under Arch Linux ↵
Vaibhav Gupta
1
-1
+1
(installation of Sphinx).
2019-02-28
Add commands and output to the README.
Chris Johns
1
-4
+24
2019-02-28
Add a cheetsheet link to the README.txt
Chris Johns
1
-0
+4
2019-02-28
waf: Change --sphinx-verbose to --sphinx-options, add --sphinx-nit-pick
Chris Johns
1
-4
+40
Provide options to manage sphinx. Make using the nit-picky mode simpler to access.
2019-02-13
README.txt: Fix typos
Joel Sherrill
1
-2
+2
2018-11-16
README.txt: Fix grammar errors (GCI 2018)
Aneendya
1
-3
+3
2018-11-03
user: Add RTEMS executable and test documentation.
Chris Johns
1
-2
+41
2018-11-03
waf: Add support to build PlantUML and Ditaa images.
Chris Johns
1
-1
+16
2017-07-26
README: fix typos
Gedare Bloom
1
-8
+8
2017-05-31
Fixes typos in README.txt
Tanu Hari Dixit
1
-2
+2
2 typos fixed
2017-04-25
README.txt: Add info after installing on CentOS 7
Joel Sherrill
1
-5
+22
2017-03-27
Add Windows build details.
Chris Johns
1
-0
+23
Actually include the quoting fix for Windows.
2017-02-20
Render math via JavaScript in HTML output
Sebastian Huber
1
-3
+2
2017-02-02
Update README due to use of math extension
Sebastian Huber
1
-2
+3
2017-01-20
Mention sphinxcontrib-bibtex in README
Sebastian Huber
1
-1
+3
2016-11-09
waf: Users without the extra fonts need to use '--disable-extra-fonts' to ↵
Chris Johns
1
-2
+7
build PDF.
2016-11-09
README: Add coding of spaces and no trailing white space.
Chris Johns
1
-7
+9
2016-11-09
README: Fix the header levels.
Chris Johns
1
-6
+8
2016-11-08
README.txt: Add notes on Centos 6 and 7
Joel Sherrill
1
-5
+46
2016-11-07
Add openSUSE installation hints
Sebastian Huber
1
-1
+14
2016-11-07
README: Add packages for building on Arch.
Christian Mauderer
1
-0
+12
2016-11-06
README: Update with more host specific details.
Chris Johns
1
-18
+40
2016-11-04
waf: note about tex noise when running configure.
Chris Johns
1
-0
+3
2016-11-04
README: Add host set up for CentOS for singlehtml.
Chris Johns
1
-0
+5
2016-11-04
waf: Check for texlive packages and report an error is not found.
Chris Johns
1
-3
+92
2016-11-03
README: Add host set up and update the build commands.
Chris Johns
1
-5
+38
2016-11-02
Update the top level README.txt.
Chris Johns
1
-9
+19
2016-11-01
Add some notes on writing documentation.
Chris Johns
1
-0
+130
