* | Add copyright notices | Sebastian Huber | 2019-02-08 | 9 | -0/+13 |
* | build: Prepend project common path | Sebastian Huber | 2019-02-08 | 32 | -32/+32 |
| | | | | | This avoids conflicts with standard packages such as PIL (Python Imaging Library). | ||||
* | cpu-supplement: Fix file name | Sebastian Huber | 2019-02-07 | 2 | -1/+1 |
* | Version change, forgot to add wscript to the commit. | Chris Johns | 2019-02-07 | 1 | -1/+1 |
* | Fix the version logic to make it more robust. | Chris Johns | 2019-02-07 | 1 | -1/+4 |
* | Fix building with Sphinx 1.8 and later. | Chris Johns | 2019-02-06 | 2 | -14/+33 |
| | | | | | | | | - Provide the pytnon.ist file for makeindex. - Add support for xelatex building so we can switch if we want too. Closes #3669 | ||||
* | Support VERSION file for releasing and deployment | Chris Johns | 2019-02-06 | 2 | -35/+170 |
| | | | | - Shorten the GIT hash. | ||||
* | user: Add basic event recording documentation | Sebastian Huber | 2019-02-01 | 5 | -4/+64 |
| | | | | Update #3665. | ||||
* | c-user: Add event recording configuration | Sebastian Huber | 2019-02-01 | 1 | -0/+58 |
* | bsp-howto: Fix URLs | Sebastian Huber | 2019-01-31 | 2 | -2/+2 |
* | user: Use capital letters for acronyms | Sebastian Huber | 2019-01-24 | 2 | -4/+5 |
| | | | | Fix GCC definition. | ||||
* | user: Spell out third-party | Sebastian Huber | 2019-01-24 | 11 | -21/+21 |
* | user: Stub documentation for griscv BSP | Sebastian Huber | 2019-01-22 | 1 | -0/+6 |
| | | | | Update #3678. | ||||
* | Change first copyright year to 1988 | Sebastian Huber | 2019-01-18 | 1 | -1/+1 |
| | | | | The OAR copyright goes back to 1988. | ||||
* | user: Add "Host Computer Setup" to "Quick Start" | Sebastian Huber | 2019-01-14 | 2 | -0/+20 |
* | user: Move "Prefixes" to "Quick Start" | Sebastian Huber | 2019-01-14 | 4 | -42/+57 |
| | | | | | Move "Project Sandboxing" to a separate section of the "Installation" chapter since this is an advance topic which may confuse new users. | ||||
* | user: Rework "Hardware" chapter | Sebastian Huber | 2019-01-14 | 8 | -104/+120 |
| | | | | | | | Rename it to "Target Hardware". Remove BSPs section and reference the BSPs chapter instead. Remove explicit list of architectures and reference the BSPs chapter instead. Fix typos. Elaborate multilib description in the architecture section. | ||||
* | user: Move deployment details to RSB chapter | Sebastian Huber | 2019-01-14 | 3 | -155/+164 |
* | user: Move "Ecosystem" into "Introduction" | Sebastian Huber | 2019-01-14 | 3 | -242/+239 |
* | user: Move "Support" to "Introduction" | Sebastian Huber | 2019-01-14 | 3 | -128/+125 |
| | | | | | New users may find it useful to get this information in the introduction. | ||||
* | Reformat and update copyright and license notices | Sebastian Huber | 2019-01-14 | 14 | -99/+90 |
| | | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | ||||
* | user: Add RSB content as a chapter | Sebastian Huber | 2019-01-14 | 14 | -81/+33 |
| | | | | Remove the separate RSB manual. | ||||
* | user: Remove unused file | Sebastian Huber | 2019-01-11 | 1 | -10/+0 |
* | common/header: Add missing copyright notice | Sebastian Huber | 2019-01-11 | 1 | -0/+4 |
* | rsb: Reword some sentences | Chris Johns | 2019-01-11 | 1 | -6/+6 |
* | rsb: Move content of duplicate section | Sebastian Huber | 2019-01-11 | 4 | -66/+24 |
| | | | | | Move "Controlling the Tools Build" section and "Building Tools and RTEMS" chapter to "Project Sets" chapter and "RTEMS" section. | ||||
* | rsb: Move "Why Build from Source?" to own chapter | Sebastian Huber | 2019-01-11 | 3 | -56/+60 |
* | rsb: Move "History" to own chapter | Sebastian Huber | 2019-01-11 | 3 | -33/+38 |
| | | | | Move it to the end of the document. It is auxiliary information. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 272 | -272/+272 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 178 | -178/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 235 | -378/+262 |
* | user: Add TODO entries for all BSP families | Sebastian Huber | 2019-01-09 | 16 | -6/+370 |
| | | | | Update #3464. | ||||
* | rsb: Fix chapter layout | Sebastian Huber | 2019-01-09 | 1 | -3/+0 |
* | user: Rework overview | Sebastian Huber | 2019-01-09 | 3 | -31/+233 |
| | | | | | | Move "Overview", "Real-time Applicaiton Systems" and "Real-time Executive" chapters as sections into new "Introduction" chapter. Add "Feature" section. | ||||
* | Update header.rst | Sebastian Huber | 2019-01-09 | 1 | -10/+10 |
| | | | | Remove trailing slashes in URLs. Fix bug reporting URL. | ||||
* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 15 | -322/+37 |
* | Remove superfluous word "Copyright" | Sebastian Huber | 2019-01-09 | 1 | -1/+1 |
| | | | | The © symbol is sufficient. | ||||
* | Update general copyright notice | Sebastian Huber | 2019-01-09 | 1 | -1/+1 |
| | | | | Update year and add "and contributors". | ||||
* | Replace build date with Git hash and commit date | Sebastian Huber | 2019-01-09 | 3 | -47/+39 |
| | | | | The usage of a build date prevents reproducible builds. | ||||
* | cpu-supplement: Update ARM multilibs | Sebastian Huber | 2019-01-07 | 1 | -7/+18 |
* | c-user: Fix typos | Frédéric Jouault | 2019-01-04 | 2 | -4/+4 |
| | | | | Close #3261. | ||||
* | sparc_v8_stacks_regwin.rst: Add middle initail for Peter Magnusson | Joel Sherrill | 2018-12-20 | 1 | -2/+2 |
| | | | | | | Peter requested this after reviewing the converted content. He noted that it was a nit but he had consistently used his middle initial in all academic settings and wanted to be consistent. | ||||
* | Eliminate UTF-8 characters except superscripted 2 in i2c | Joel Sherrill | 2018-12-20 | 9 | -22/+22 |
* | eng: Unicode char (U+200B) | Sebastian Huber | 2018-12-20 | 1 | -3/+3 |
* | common/waf.py: Fix indentation. | Christian Mauderer | 2018-12-18 | 1 | -1/+1 |
| | | | | Python 3 produces an error if indentation is mixed tabs and spaces. | ||||
* | eng/coding-conventions.rst: Convert TBD to Rest Format (GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -2/+244 |
* | eng/coding-doxygen: Fix errors | Marçal Comajoan Cara | 2018-12-17 | 1 | -352/+360 |
| | | | | This work was part of GCI 2018. | ||||
* | eng/coding-file-hdr.rst: Fix file formatting (GCI 2018) | Sal | 2018-12-17 | 1 | -23/+25 |
* | eng/coding-doxygen.rst: Clean up and make subsubsections | Joel Sherrill | 2018-12-17 | 1 | -315/+362 |
* | Converted Doxygen Best Practices Documentation to Rest format (GCI 2018) | zehata | 2018-12-17 | 1 | -1/+417 |
