* | Add support for spellchecking with a custom dictionary. | Amar Takhar | 2016-05-02 | 17 | -15/+66 |
| | | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | ||||
* | Convert all Unicode to ASCII(128) | Amar Takhar | 2016-05-02 | 121 | -705/+705 |
* | Remove ada_user document. | Amar Takhar | 2016-05-02 | 43 | -45880/+0 |
| | | | | | | | | | We are going to make Ada a chapter in the c_user manual to simplify things. Talked it over with Joel the differences between ada_user and c_users are a lot smaller than they used to be. A simple few page chapter will be enough for anyone to know the differences and will be a lot easier to maintain. | ||||
* | Rework how conf.py is handled. | Amar Takhar | 2016-05-02 | 29 | -159/+167 |
| | | | | Needed to switch due to increasing complexity. | ||||
* | Fix rtemsconfig building. | Amar Takhar | 2016-05-02 | 4 | -8/+31 |
| | | | | | I'll probably move to a more pythonic way of doing conf.py since this is getting too complicated. | ||||
* | Delete new_chapters document as it is rarely used. | Amar Takhar | 2016-05-02 | 3 | -513/+0 |
| | | | | | | | | Joel says this was a template used to generate a shell when adding a set of related APIs. It was written in 1997 and a good portion is untouched. If we need this functionality in the new docs we can write something much nicer using Python to generate the proper reST documentation. | ||||
* | Remove relnotes are per Joel -- it has no use anymore. | Amar Takhar | 2016-05-02 | 3 | -574/+0 |
| | | | | | It is severely out of date we will write new information elsewhere. Plus the new website has a lot of similar info. | ||||
* | Rename old document for reference only. | Amar Takhar | 2016-05-02 | 1 | -0/+0 |
* | Split document into seperate files by section. | Amar Takhar | 2016-05-02 | 40 | -1/+23750 |
* | Fix markup. | Amar Takhar | 2016-05-02 | 1 | -122/+173 |
* | Split document into seperate files by section. | Amar Takhar | 2016-05-02 | 41 | -1/+22914 |
* | Fix markup. | Amar Takhar | 2016-05-02 | 1 | -162/+214 |
* | Split document into seperate files by section. | Amar Takhar | 2016-05-02 | 25 | -1/+11564 |
* | Fix warnings. | Amar Takhar | 2016-05-02 | 1 | -0/+4 |
* | Split document into seperate files by section. | Amar Takhar | 2016-05-02 | 21 | -1/+4541 |
* | Fix warnings. | Amar Takhar | 2016-05-02 | 1 | -33/+81 |
* | Clean up of general commands. | Chris Johns | 2016-05-02 | 1 | -308/+319 |
* | Split document into seperate files by section. | Amar Takhar | 2016-05-02 | 20 | -1/+4723 |
* | Fix warnings. | Amar Takhar | 2016-05-02 | 1 | -19/+28 |
* | Split document into seperate files by section. | Amar Takhar | 2016-05-02 | 22 | -1/+3609 |
* | Fix warnings. | Amar Takhar | 2016-05-02 | 1 | -12/+4 |
* | Move preface/intro one level up so the section is unnumbered. | Amar Takhar | 2016-05-02 | 3 | -3/+6 |
* | Split document into seperate files by section. | Amar Takhar | 2016-05-02 | 13 | -1/+1858 |
* | Fix markup | Amar Takhar | 2016-05-02 | 1 | -0/+2 |
* | Split document. | Amar Takhar | 2016-05-02 | 10 | -1/+1992 |
* | Fix markup | Amar Takhar | 2016-05-02 | 1 | -6/+47 |
* | Fix images. | Amar Takhar | 2016-05-02 | 4 | -12/+3 |
* | Clean up config and init. | Chris Johns | 2016-05-02 | 1 | -26/+25 |
* | Split document. | Amar Takhar | 2016-05-02 | 11 | -1/+7005 |
* | Clean up the alias command. | Chris Johns | 2016-05-02 | 1 | -34/+33 |
* | Cleaned up to General Commands. | Chris Johns | 2016-05-02 | 1 | -346/+246 |
* | Split document. | Amar Takhar | 2016-05-02 | 7 | -1/+1329 |
* | Fix warnings. | Amar Takhar | 2016-05-02 | 1 | -25/+10 |
* | Fix section numbering, create TOC, seperate preface. | Amar Takhar | 2016-05-02 | 2 | -58/+12 |
* | Split document into seperate files by section. | Amar Takhar | 2016-05-02 | 11 | -1/+4599 |
* | Fix markup warnings. | Amar Takhar | 2016-05-02 | 1 | -2/+21 |
* | Fix references. | Amar Takhar | 2016-05-02 | 1 | -9/+3 |
* | Fix broken markup. | Amar Takhar | 2016-05-02 | 1 | -1/+44 |
* | Check for non existent directories when building 'book'. | Amar Takhar | 2016-05-02 | 1 | -2/+6 |
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 109 | -0/+92496 |
