* | eng/vc-authors: Convert wiki page to Rest (GCI 2018) | Marçal Comajoan Cara | 2018-12-17 | 2 | -2/+353 |
| | | | | | | | | | Converted https://devel.rtems.org/wiki/Developer/Git/Committers to Rest, and TBDs and wiki TODOs into comments. Also changed http links to https (the ones that are possible), corrected some typos, created a folder for eng images and added some formatting. This work was part of GCI 2018. | ||||
* | management: Convert TBD to rest Format (GCI 2018) | Pritiah Jain | 2018-12-17 | 2 | -2/+154 |
* | eng/conf.py: Use new short name of SW Eng Handbook | Marçal Comajoan Cara | 2018-12-17 | 1 | -1/+1 |
* | eng/license-requirements.rst: Add a TBD for BSD info | Joel Sherrill | 2018-12-17 | 1 | -0/+1 |
* | coding-doxygen-bsp.rst, coding-file-hdr.rst: Fix formatting | Joel Sherrill | 2018-12-17 | 2 | -321/+651 |
* | coding-file-hdr: Convert TBD to Rest Format (GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -3/+33 |
* | coding-doxygen-bsp: Convert TBD to rest Format(GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -4/+384 |
* | coding-gen-patch:Convert TBD to rest Format(GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -2/+27 |
* | eng/coding-80cols: Convert wiki page to Rest | Marçal Comajoan Cara | 2018-12-17 | 1 | -2/+146 |
| | | | | | | | Converted https://devel.rtems.org/wiki/Developer/Coding/80_characters_per_line to Rest, and TBDs into comments. This work was part of GCI 2018. | ||||
* | eng/appendix-a: convert to a table | Marçal Comajoan Cara | 2018-12-17 | 1 | -50/+106 |
| | | | | | | | Convert text to a table, TBDs into comments and add missing formatting. This work was part of GCI 2018. | ||||
* | eng/test-suites.rst: Update to reflect current reality | Joel Sherrill | 2018-12-17 | 1 | -6/+24 |
* | test-suites:Convert TBD to rest Format(GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -3/+32 |
* | Initial start of converting the Word outline to Rest | Joel Sherrill | 2018-12-17 | 31 | -0/+650 |
| | | | | | Thanks to Scott Zemerick <scott.zemerick@tmctechnologies.com> for the analysis and ideas that led to this. | ||||
* | Integrate images redrawn as part of GCI 2018 | Marçal Comajoan Cara | 2018-12-11 | 25 | -3/+817 |
| | | | | | | | All of the redrawings were made by me except images/c_user/states which was made by LukaMag. This patch serves to update all the images. This work was part of GCI 2018. | ||||
* | c-user: rtems_scheduler_get_maximum_priority() | Sebastian Huber | 2018-12-10 | 1 | -0/+37 |
| | | | | Close #3636. | ||||
* | posix-compliance: Change utimes() from sys/times.h to sys/time.h | Marçal Comajoan Cara | 2018-12-09 | 2 | -8/+8 |
| | | | | | | | | | | | | | | | | | | | In the RTEMS POSIX 1003.1 Compliance Guide it says: The following methods and variables in <sys/times.h> are supported: - times() - utimes() But according to the official POSIX Specifications http://pubs.opengroup.org/onlinepubs/9699919799/basedefs/sys_times.h.html, <sys/times.h> only declares times(), and utimes() is decleared by <sys/time.h> (notice that it's time, not times) according to http://pubs.opengroup.org/onlinepubs/9699919799/functions/utimensat.html and http://pubs.opengroup.org/onlinepubs/9699919799/basedefs/sys_time.h.html. This patch fixes this error. This work was part of GCI 2018. | ||||
* | Fix error messages when Sphinx version cannot be checked. | Amar Takhar | 2018-12-05 | 1 | -2/+2 |
| | | | | | | | | | | This is kind of a dual-check since it checks for the version while simultaneously checking to see if Sphinx exists on the system. Changed the error messages to be clear on the error and removed a reference to version which cannot be set due to the check failure. Reported by: Shashvat Jain | ||||
* | posix-users/input_and_output.rst: Document errors for mount() and unmount() | Joel Sherrill | 2018-11-21 | 1 | -4/+15 |
* | posix-users/device_and_class_specific.rst: Add Prototypes | Marçal Comajoan Cara | 2018-11-21 | 1 | -20/+28 |
| | | | | | | | Add and update Device and Class Specific APIs in POSIX Users Guide. This work was part of GCI 2018. | ||||
* | posix-users/input_and_output.rst: Add Prototypes | Marçal Comajoan Cara | 2018-11-21 | 1 | -28/+56 |
| | | | | | | | Add and update Prototypes to Input and Output APIs in POSIX Users Guide. This work was part of GCI 2018. | ||||
* | posix-users/memory_managment.rst: Add Prototypes | Marçal Comajoan Cara | 2018-11-21 | 1 | -0/+22 |
| | | | | | | Add Prototypes to Memory Management APIs in POSIX Users Guide. This work was part of GCI 2018. | ||||
* | posix-users/system_database.rst: Add Prototypes | Marçal Comajoan Cara | 2018-11-21 | 1 | -4/+36 |
| | | | | | | Add Prototypes to System Database APIs in POSIX Users Guide. This work was part of GCI 2018. | ||||
* | posix-users/thread_cancellation.rst: Add Prototypes | Marçal Comajoan Cara | 2018-11-21 | 1 | -3/+18 |
| | | | | | | Add Prototypes to Thread Cancellation APIs. This work was part of GCI 2018. | ||||
* | posix-users/language_specific_services.rst: Add Prototypes to Language ↵ | Marçal Comajoan Cara | 2018-11-21 | 1 | -42/+48 |
| | | | | | | Specific Service APIs This work was part of GCI 2018. | ||||
* | c-user: Remove 16-bit object identifiers | Sebastian Huber | 2018-11-21 | 1 | -36/+8 |
| | | | | Close #3603. | ||||
* | cpu-supplement/sparc.rst: Merge Annul Slot Explanation (GCI 2018) | zehata | 2018-11-20 | 1 | -0/+45 |
| | | | | | This content originated as an email response from Jiri Gaisler to Joel Sherrill in response to a question. | ||||
* | cpu-supplement/sparc_v8_stacks_regwin.rst: Add credit box | Joel Sherrill | 2018-11-20 | 1 | -0/+8 |
* | cpu-supplement/sparc_v8_stacks_regwin.rst: Complete Formatting | Marçal Comajoan Cara | 2018-11-20 | 1 | -49/+48 |
* | images/cpu_supplement/sparcwin.svg: New file (GCI 2018) | Marçal Comajoan Cara | 2018-11-19 | 1 | -0/+176 |
| | | | | File was missed in previous commit. | ||||
* | cpu-supplement/sparc_v8_stacks_regwin.rst: Simplify section title | Joel Sherrill | 2018-11-19 | 1 | -2/+2 |
* | Improve SPARC Calling Overview Webpage conversion | Marçal Comajoan Cara | 2018-11-19 | 6 | -209/+187 |
| | | | | | | | | | Fixed tables, typos, redrawn images and converted ASCII art to ditaa and PNG, and improved the overall format. This work was part of GCI 2018. Closes #3567. | ||||
* | cpu-supplement/sparc_v8_stacks_regwin.rst: Basic formatting with TBDs | Joel Sherrill | 2018-11-19 | 1 | -51/+271 |
| | | | | Leaving notes for follow up as a GCI 2018 task. | ||||
* | Initial addition of SPARC V8 Stack/Register Windowing from Peter Magnusson | Joel Sherrill | 2018-11-19 | 2 | -0/+413 |
| | | | | | | | | | This content was originally at https://www.sics.se/~psm/sparcstack.html and is currently only available via the Wayback Machine. Peter kindly gave permission to include it with the RTEMS Documentation. This initial commit is a cut and paste with minimal edits. Edits are needed to ensure proper formatting and the figures need to be made to look correct in the Rest formatted output. | ||||
* | users/host/posix.rst: Update Ubuntu instructions based on 18.04.1 LTS | Joel Sherrill | 2018-11-16 | 1 | -3/+13 |
| | | | | Closes #3416. | ||||
* | README.txt: Fix grammar errors (GCI 2018) | Aneendya | 2018-11-16 | 1 | -3/+3 |
* | glossary.rst: Fix grammar errors (GCI 2018) | Aneendya | 2018-11-16 | 2 | -4/+4 |
* | user: add a warning not to use special characters in pathnames | Marçal Comajoan Cara | 2018-11-16 | 1 | -0/+7 |
| | | | | | | | | | | | | | | | Spaces and other specical characters in pathnames break builds of any software packages using GNU make. All of the GNU tools and RTEMS use make and this breaks builds. This is a long standing known issue with GNU make, which can't handle spaces in pathnames: https://savannah.gnu.org/bugs/?712 This work was part of GCI 2018. Probably closes #3450. | ||||
* | c-user: Update type deprecation | Sebastian Huber | 2018-11-16 | 1 | -10/+5 |
| | | | | | | Update #3584. Update #3587. Update #3589. | ||||
* | Remove m32c architecture port | Sebastian Huber | 2018-11-09 | 2 | -11/+2 |
| | | | | Update #3599. | ||||
* | user: spelling and grammar fixes | Marçal Comajoan Cara | 2018-11-09 | 2 | -5/+5 |
* | user: Update architecture list | Sebastian Huber | 2018-11-08 | 1 | -1/+3 |
* | user: Remove obsolete boostrap -p step | Sebastian Huber | 2018-11-08 | 1 | -44/+2 |
| | | | | Update #3254. | ||||
* | c-user: Use common wording for build config opts | Sebastian Huber | 2018-11-05 | 2 | -7/+7 |
* | c-user: Update POSIX API configuration | Sebastian Huber | 2018-11-05 | 1 | -11/+22 |
| | | | | Close ##2514. | ||||
* | user: Add RTEMS executable test generated images. | Chris Johns | 2018-11-03 | 15 | -0/+0 |
* | user: Add RTEMS executable and test documentation. | Chris Johns | 2018-11-03 | 33 | -49/+1934 |
* | waf: Add support to build PlantUML and Ditaa images. | Chris Johns | 2018-11-03 | 5 | -2/+99 |
* | User: Simplify the top level headings. | Chris Johns | 2018-11-03 | 4 | -10/+26 |
* | Document CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS | Sebastian Huber | 2018-10-30 | 1 | -0/+32 |
* | c-user/message_manager.rst: Change "cons void" to "const void" | Joel Sherrill | 2018-10-29 | 1 | -1/+1 |
| | | | | Closes #3575. |
