* | Shorten the name of the BSP and Device Driver Development Guide | Joel Sherrill | 2017-10-12 | 5 | -17/+11 |
| | | | | | | | | | | | | | Old name: RTEMS BSP and Device Driver Development Guide This is long and causes problems in the PDF output. This patch changes the name to: RTEMS BSP and Driver Guide Closes #3141. | ||||
* | c-user: CONFIGURE_MAXIMUM_POSIX_SEMAPHORES | Sebastian Huber | 2017-10-12 | 1 | -6/+30 |
| | | | | | | | This configuration is not obsolete since it is still used for named semaphores. Update #3116. | ||||
* | posix-users/thread.rst: Add pthread_getconcurrency and pthread_setconcurrency | Joel Sherrill | 2017-10-11 | 1 | -0/+69 |
| | | | | Closes #2680. | ||||
* | c-user: Update to reflect rtems_clock_get() being obsoleted. | Joel Sherrill | 2017-10-11 | 2 | -95/+22 |
| | | | | Closes #2693. | ||||
* | c-user: Add obsolete configuration options section | Sebastian Huber | 2017-10-09 | 1 | -164/+88 |
| | | | | | | | | | Update #2493. Update #3112. Update #3113. Update #3114. Update #3115. Update #3116. | ||||
* | c-user: Clarify that confdefs.h is mandatory | Sebastian Huber | 2017-10-06 | 1 | -21/+3 |
* | Mention i.MX 7 SMP support | Sebastian Huber | 2017-09-27 | 1 | -2/+7 |
| | | | | Update #3090. | ||||
* | bsp-howto: Clock_driver_support_install_isr() | Sebastian Huber | 2017-09-18 | 1 | -3/+5 |
| | | | | Close #3139. | ||||
* | Improve the line spaces for directives and notes. | Chris Johns | 2017-09-14 | 1 | -7/+20 |
* | c-user: Fix task create notes | Sebastian Huber | 2017-09-14 | 1 | -2/+6 |
* | c-user: Clarify SMP's rtems_get_processor_count. | Chris Johns | 2017-09-14 | 1 | -1/+4 |
* | Add PAX to the Ubuntu packages to install. | Chris Johns | 2017-09-04 | 1 | -1/+1 |
| | | | | Closes #3008. | ||||
* | Eclipse: Fix TOC and glossary licence comment. | Chris Johns | 2017-09-04 | 2 | -5/+1 |
* | common: Remove obsolete latex_use_parts | Sebastian Huber | 2017-08-25 | 1 | -4/+0 |
| | | | | | | | | This configuration is obsolete and no longer documented: http://www.sphinx-doc.org/en/stable/config.html#options-for-latex-output The use of parts at the top-level results in ugly documents. | ||||
* | cpu-supplement: Use literal instead of emphasis | Sebastian Huber | 2017-08-25 | 1 | -10/+11 |
| | | | | Update #3082. | ||||
* | cpu-supplement: Fix PowerPC TOC limitation | Sebastian Huber | 2017-08-24 | 1 | -2/+3 |
* | c-user: Clarify user extensions | Sebastian Huber | 2017-08-24 | 1 | -59/+66 |
| | | | | Close #2367. | ||||
* | cpu-supplement/powerpc: Rewrite | Sebastian Huber | 2017-08-23 | 1 | -475/+38 |
| | | | | | | | Remove obsolete and duplicated information. Reference the ABI specifications. Add 64-bit caveats. Update #3082. | ||||
* | coverpage: Fix repeated entries. | Chris Johns | 2017-08-11 | 2 | -2/+4 |
| | | | | Closes #2865. | ||||
* | Update copyright notices. | Chris Johns | 2017-08-11 | 15 | -83/+142 |
* | pdf: Update the RTEMS style to work recent Sphinx versions. | Chris Johns | 2017-08-11 | 1 | -54/+23 |
* | common/conf: Clean up. | Chris Johns | 2017-08-11 | 1 | -4/+0 |
* | Revert "Add the sphinxcontrib.bibtex extension to the repo." | Chris Johns | 2017-08-09 | 8 | -975/+1 |
| | | | | | | This reverts commit aa4f8e2e436d6c49e1524a4a3fb164b28632d894. The contrib has too many dependencies to add into the repo. | ||||
* | Add the sphinxcontrib.bibtex extension to the repo. | Chris Johns | 2017-08-07 | 8 | -1/+975 |
* | bsp: Optional clock driver shutdown | Sebastian Huber | 2017-08-04 | 1 | -4/+8 |
* | memory_management: update mmap, munmap, shm_open, shm_unlink | Gedare Bloom | 2017-07-28 | 1 | -9/+140 |
| | | | | Close #2859. | ||||
* | posix1003-1, posix_users: mark mmap and shm functions implemented | Gedare Bloom | 2017-07-28 | 3 | -24/+23 |
| | | | | Update #2859. | ||||
* | README: fix typos | Gedare Bloom | 2017-07-26 | 1 | -8/+8 |
* | c-user: Fix interrupt lock documentation | Sebastian Huber | 2017-07-14 | 1 | -17/+35 |
| | | | | Update #3075. | ||||
* | c-user: Document new scheduler ident routines | Sebastian Huber | 2017-07-12 | 1 | -0/+83 |
| | | | | | Close #3069. Close #3070. | ||||
* | c-user: Update scheduler/task chapter | Sebastian Huber | 2017-07-10 | 2 | -34/+87 |
| | | | | | | | Reflect EDF SMP scheduler changes. Close #3059. Close #3063. | ||||
* | c-user: Document EDF SMP | Sebastian Huber | 2017-06-30 | 2 | -0/+34 |
| | | | | Close #3056. | ||||
* | shell: Update task command | Sebastian Huber | 2017-06-16 | 1 | -3/+3 |
* | User Manual: Added rtems-tester in the docs | Tanu Hari Dixit | 2017-06-14 | 2 | -0/+447 |
| | | | | | | | Added as part of Tools. Made changes according to Chris' review Also removed the ini format part inline with the new release that is expected. | ||||
* | docs/rsb/configuration.rst: Fix typos, grammar. | Cillian O'Donnell | 2017-06-14 | 1 | -28/+28 |
* | cpu-supplement: Update TLS support status | Sebastian Huber | 2017-06-12 | 1 | -1/+1 |
| | | | | Close #2468. | ||||
* | bsp-howto: Warn about TERMIOS_TASK_DRIVEN | Sebastian Huber | 2017-06-08 | 1 | -0/+2 |
| | | | | Update #2935. | ||||
* | rsb: Mention Ada language option | Sebastian Huber | 2017-06-06 | 1 | -3/+6 |
* | User: Remove conflict marker. | Chris Johns | 2017-06-01 | 1 | -1/+0 |
* | User: Remove the stash conflict markers. | Chris Johns | 2017-05-31 | 1 | -4/+0 |
* | Fixes typos in README.txt | Tanu Hari Dixit | 2017-05-31 | 1 | -2/+2 |
| | | | | 2 typos fixed | ||||
* | User: Improvements to some of the tools commands. | Chris Johns | 2017-05-31 | 3 | -50/+51 |
* | User Manual: Update the rtems-bsp-builder command. | Chris Johns | 2017-05-24 | 1 | -420/+282 |
* | c-user: Replace pre-emption with preemption | Sebastian Huber | 2017-05-11 | 2 | -8/+8 |
* | hosts.rst: Correct Ubuntu instructions | Linda Huxley | 2017-04-25 | 1 | -2/+2 |
| | | | | closes #3005. | ||||
* | README.txt: Add info after installing on CentOS 7 | Joel Sherrill | 2017-04-25 | 1 | -5/+22 |
* | c-user/rate_monotonic_manager.rst: Use Latex math for utilization formulas | Joel Sherrill | 2017-04-25 | 1 | -9/+8 |
* | POSIX Users: Add posix_devctl() | Joel Sherrill | 2017-04-25 | 2 | -0/+76 |
* | Add Windows build details. | Chris Johns | 2017-03-27 | 2 | -1/+24 |
| | | | | Actually include the quoting fix for Windows. | ||||
* | waf: Fix linkcheck and spell commands. | Chris Johns | 2017-03-27 | 2 | -45/+27 |
| | | | | | | Clean up and remove code that is not needed. Fix sphinx-build quoting to work on Windows. |
